What is the moment of inertia of a disk with a hole about the Z-axis?
In summary, the moment of inertia of the modified disk about the Z-axis is 202956.7789 g cm^2. This is found by treating the disk as two separate objects - the modified disk and the cutout part - and using the parallel-axis theorem to calculate their individual moments of inertia.
ledphones
A uniform circular disk has radius 39 cm and mass 350 g and its center is at the origin. Then a circular hole of radius 9.75 cm is cut out of it. The center of the hole is a distance 14.625 cm from the center of the disk. Find the moment of inertia of the modified disk about the Z-axis.
a) answer is in g cm^2
HELP: Think of the disk as the sum of the modified disk plus the cutout part.
HELP: Using the hint, apply the definition of moment of inertia. That is, consider the whole disk (disk without hole) to be composed of two constituent objects (modified disk plus cutout part). Then think about the answers to the following questions and try to figure out how answering these questions leads you to solve the problem:
How is the moment of inertia of the disk related to the moments of inertia of the modified disk and the cutout part?
What is the moment of inertia of the disk about the origin?
What is the mass of the cutout part?
What is the moment of inertia of the cutout part about the center of the cutout part?
What is the moment of inertia of the cutout part about the origin?
1/2MR^2
Parallel-Axis Theorem (I=Icm+M(h)^2) where Icm is I subscript center of mass
I found the mass to be .0781299743 grams per cm^2 from 350/((39^2)*pi-(9.75^2)*pi)
I then multiplied this by (39^2)*pi and (9.75^2)*pi to get the mass of the disk without a hole as 373.33 grams and the mass of the hole to be 23.33 grams.
Next I found the inertia of the disk w/o the hole
I=.5MR^2
.5(373.33)39^2 = 283917.47
I then found the inertia of the hole with the parallel-axis theorem
.5M(r)^2+M(h)^2
.5(23.33)(9.75)^2+(23.33)(14.625)^2 = 6098.97
I then subtracted the inertia of the disk w/o the hole and the inertia of the hole. which should give me the disk w/o the hole
(28317.47-6098.97)=277818.5
This was wrong please help!
I also tried the disk without the hole but multiplied the hole's h by the mass of the disk without the hole and the mass of the disk.
.5(23.33)(9.75)^2+(373.33)(14.625)^2
.5(23.33)(9.75)^2+(350)(14.625)^2
attaining 202956.7789and 207946.85 respectively
You may find it easier to think of the disk as composed of two parts. First is the whole disk without any holes. Second is a smaller mass in the middle of negative mass to compensate for the hole.
edit: looking a bit more closely at what you've written, your density term seems to be off. Can you tell me exactly how you got that?
I took the mass of the large disk without a hole found the area (39*39*pi) and subtracted the area of the hole (9.75*9.75*pi) and then i divided the total mass by this to find the density.
Ah, you can't really do that. The mass given is the mass of the disk without the hole. So to find the density, you divide the mass by the volume of the disk without the hole. You don't need to subtract away anything.
Thank you so much! That was exactly what I was doing wrong. Mass was the mass of the disk with the hole. Not the disk without the hole.
What is the concept of disk with hole inertia?
The concept of disk with hole inertia refers to the measurement of an object's resistance to changes in rotational motion. It takes into account the shape, mass distribution, and angular velocity of an object with a central hole or void in the middle.
How is disk with hole inertia different from regular disk inertia?
Disk with hole inertia differs from regular disk inertia in that it takes into account the distribution of mass around the central hole. Regular disk inertia only considers the mass distribution around the outer circumference of the disk.
What is the formula for calculating disk with hole inertia?
The formula for calculating disk with hole inertia is I = 1/2 * (M*R2 + m*r2), where I is the moment of inertia, M is the mass of the disk, R is the outer radius, m is the mass of the hole, and r is the radius of the hole.
What factors affect the disk with hole inertia?
The factors that affect disk with hole inertia include the mass of the disk, the shape and size of the hole, and the distance of the hole from the center of the disk. The distribution of mass around the hole also plays a role in determining the inertia of the object.
Why is understanding disk with hole inertia important in science?
Understanding disk with hole inertia is important in science because it allows us to predict the behavior of rotating objects with a central hole or void. This knowledge is essential in fields such as engineering, physics, and mechanics, where the motion and stability of rotating objects are crucial.
