Displacement and pressure in sound wave
In summary, displacement in a sound wave refers to the distance a particle moves from its rest position, and is directly proportional to amplitude. Factors such as frequency, amplitude, and speed of the wave, as well as the properties of the medium, affect displacement. Pressure is also directly proportional to displacement, and can be measured using instruments such as a microphone and pressure sensor. These measurements can be displayed on a waveform graph.
denian
641
there is one formula given as follow
(max pressure ) = (speed of wave)X(density of medium)X(angular frequency of the wave ) X (maximum displacement)
in the book, there is no working shown how to arrive to this formula. anyone can show me the steps? thank you.
(sorry, i don't know how to insert the symbols)
consider
[tex]
s=s_m\sin(kx-\omega t)[/tex]
[tex] \Delta p=-B\frac{ds}{dx}[/tex]
[tex]\Delta p(x,t) = Bks_m\sin(kx-\omega t)[/tex]
[tex]
B=\rho v^2
[/tex]
[tex]k=\frac{\omega}{v}[/tex]
hence u get
[tex]\Delta p_m=\omega v \rho s_m [/tex]
The formula given is known as the acoustic pressure formula and it is derived from the basic principles of wave motion. To understand how this formula is derived, we need to first understand the concepts of displacement and pressure in sound waves.
Displacement refers to the distance that a particle in the medium moves from its equilibrium position when a sound wave passes through it. This displacement can be positive (when the particle moves away from its equilibrium position) or negative (when the particle moves towards its equilibrium position).
Pressure, on the other hand, refers to the force per unit area that the sound wave exerts on the medium as it propagates through it. When a sound wave passes through a medium, it compresses and rarefies the particles in that medium, causing changes in pressure.
Now, let's break down the formula step by step:
1. (Maximum pressure): This refers to the maximum pressure that the sound wave exerts on the medium. This pressure is directly proportional to the maximum displacement of the particles in the medium. In other words, the greater the maximum displacement, the greater the maximum pressure.
2. (Speed of wave): This refers to the speed at which the sound wave travels through the medium. This speed is determined by the properties of the medium, such as its density and elasticity. Generally, sound waves travel faster in denser and more elastic mediums.
3. (Density of medium): This refers to the density of the medium through which the sound wave is propagating. Density is defined as the mass per unit volume of a substance. The denser the medium, the more particles there are to compress and rarefy, resulting in a greater pressure.
4. (Angular frequency of the wave): This refers to the frequency at which the sound wave oscillates in a circular motion. It is related to the regular frequency of the wave (measured in Hertz) by the formula: angular frequency = 2π x frequency. The higher the frequency or angular frequency, the more cycles of compression and rarefaction occur in a given time, resulting in a greater pressure.
5. (Maximum displacement): As mentioned earlier, this refers to the maximum displacement of the particles in the medium as the sound wave passes through it. This displacement is directly proportional to the maximum pressure exerted by the sound wave.
By combining all these factors, we arrive at the acoustic pressure formula: (Max pressure) = (Speed of wave) x (Density of medium) x (Angular frequency
1. What is displacement in a sound wave?
Displacement in sound wave refers to the distance that a particle in a medium moves from its rest position as a result of the sound wave passing through it. It is usually measured in meters.
2. How is displacement related to amplitude in a sound wave?
Displacement is directly proportional to amplitude in a sound wave. This means that as displacement increases, so does the amplitude of the sound wave. Amplitude is a measure of the maximum displacement of a particle from its rest position.
3. What factors affect the displacement of a sound wave?
The displacement of a sound wave is affected by the frequency, amplitude, and speed of the wave. The medium through which the wave travels can also affect its displacement, as different mediums have different densities and properties.
4. How is pressure related to displacement in a sound wave?
Pressure is directly proportional to displacement in a sound wave. As the displacement of particles in the medium increases, the pressure also increases. This is because the particles in the medium are closer together, resulting in a higher pressure.
5. How can displacement and pressure be measured in a sound wave?
Displacement and pressure in a sound wave can be measured using various instruments such as a microphone, which measures the displacement of air particles, and a pressure sensor, which measures the changes in air pressure caused by the sound wave. These measurements can be displayed on a graph called a waveform, which shows the changes in displacement and pressure over time.
9K
