I got 0.60 as the answer, does this indicate that the graph has shifted 0.60m as a result??Rellek said:Hey there!
Well, this is a transverse wave and they tell you that no energy is lost or anything like that, and also they give you the apparent velocity of the wave. Perhaps using the definition of velocity will give you the phase shift of this graph after .05 seconds?
$$V = \frac {ds}{dt} \Rightarrow Vt = s$$
LXX said:I got 0.60 as the answer, does this indicate that the graph has shifted 0.60m as a result??
A displacement-distance graph is a graphical representation of the relationship between the displacement and distance traveled by an object. It shows how far an object has moved from its original position and the total distance it has traveled over a certain period of time.
A displacement-distance graph shows the actual distance an object has traveled, while a position-time graph shows the change in position of an object over time. A displacement-distance graph is a snapshot of an object's motion at a specific point in time, while a position-time graph shows the entire motion of an object over a period of time.
The slope of a displacement-distance graph represents the speed or velocity of an object. A steeper slope indicates a higher speed, while a flatter slope indicates a lower speed.
The average speed can be calculated by dividing the total distance traveled by the total time taken. In a displacement-distance graph, the average speed can also be determined by finding the slope of the graph.
The units used in a displacement-distance graph are distance (such as meters or kilometers) on the y-axis and time (such as seconds or hours) on the x-axis. The slope of the graph is measured in distance over time, such as meters per second or kilometers per hour.
