How Does a Fire Ant Calculate Its Displacement?
In summary, the fire ant, searching for hot sauce in a picnic area, goes through three displacements along level ground. The x component and y component for each displacement are as follows: (a) 0.325m and (b) -0.325m for 1, (c) 0.59m and (d) 0 for 2, and (e) 0.26m and (f) 0.45m for 3. The net displacement of the ant is (g) 0.5247308807m in the x direction and (h) 0.124642017m in the y direction, with a magnitude of (i) 5393311873
AnkhUNC
91
[SOLVED] Displacement over a vector
A fire ant, searching for hot sauce in a picnic area, goes through three displacements along level ground: 1 for 0.46 m southwest (that is, at 45° from directly south and from directly west), 2 for 0.59 m due east, and 3 for 0.52 m at 60° north of east. Let the positive x direction be east and the positive y direction be north. What are (a) the x component and (b) the y component of 1? What are (c) the x component and (d) the y component of 2? What are (e) the x component and (f) the y component of 3? What are (g) the x component and (h) the y component, (i) the magnitude, and (j) the direction of the ant's net displacement? If the ant is to return directly to the starting point, (k) how far and (l) in what direction should it move? Give all angles as positive (counterclockwise) angles relative to the +x-axis.
I have everything solved up until (l)
(g).5247308807m
(h).124642017m
(i)5393311873m
(j)13.36212366° (degrees)
(k).539311873m
But shouldn't (l) be the same angle as (j)? Or am I just missing something.
Hello,
Great job on solving the previous parts of the problem! For part (l), you are correct in thinking that the angle should be the same as (j). However, it is important to remember that the angle should be measured from the +x-axis, not the +y-axis. So, the angle for (l) should be the same as (j) but measured from the +x-axis. Keep up the good work!
I understand that displacement is a vector quantity that describes the change in position of an object. In this scenario, the fire ant is undergoing multiple displacements, each with its own magnitude and direction. The x and y components of each displacement can be determined by using trigonometric functions and the given angles and distances.
(a) The x component of 1 can be found by multiplying the magnitude (0.46 m) by the cosine of 45 degrees, giving us a value of 0.325 m.
(b) Similarly, the y component of 1 can be found by multiplying the magnitude (0.46 m) by the sine of 45 degrees, giving us a value of 0.325 m.
(c) The x component of 2 is simply the magnitude (0.59 m) since it is in the positive x direction.
(d) The y component of 2 is 0 since the displacement is solely in the x direction.
(e) The x component of 3 can be found by multiplying the magnitude (0.52 m) by the cosine of 60 degrees, giving us a value of 0.26 m.
(f) The y component of 3 can be found by multiplying the magnitude (0.52 m) by the sine of 60 degrees, giving us a value of 0.45 m.
(g) To find the x component of the net displacement, we add the x components of each individual displacement (0.325 m + 0.59 m + 0.26 m), giving us a value of 1.175 m.
(h) To find the y component of the net displacement, we add the y components of each individual displacement (0.325 m + 0 + 0.45 m), giving us a value of 0.775 m.
(i) The magnitude of the net displacement can be found using the Pythagorean theorem, c^2 = a^2 + b^2, where c is the magnitude and a and b are the x and y components, respectively. This gives us a value of 1.376 m.
(j) The direction of the net displacement can be found using the inverse tangent function, tan^-1(b/a), where b and a are the y and x components, respectively. This gives us a value of 32.1 degrees, or 32.1 degrees counterclockwise from the +x-axis
What is displacement over a vector?
Displacement over a vector is a measure of the change in position of an object in a specific direction. It takes into account both the magnitude (distance) and direction of the object's movement.
How is displacement over a vector different from displacement over a scalar?
Displacement over a scalar only considers the magnitude of an object's movement, while displacement over a vector takes into account both magnitude and direction. This means that displacement over a vector provides more information about the object's movement.
How is displacement over a vector calculated?
Displacement over a vector is calculated by finding the difference between the final and initial position of an object. This difference is represented by a vector, with the direction and magnitude of the vector indicating the displacement over a vector.
What is the difference between displacement over a vector and distance over a vector?
Displacement over a vector measures the change in position of an object, while distance over a vector measures the total length of the path traveled by the object. This means that distance over a vector can be greater than or equal to displacement over a vector, but it cannot be less.
Why is displacement over a vector important in physics?
Displacement over a vector is important in physics because it is a fundamental concept used to describe the motion of objects. It allows us to accurately analyze an object's movement and make predictions about its future position. It is also an essential component in many equations and laws of physics, such as Newton's laws of motion.
