Homework Help: Displacement Problems
  1. Aug 24, 2009 #1
    A rocket starts from rest and accelerates for 3.50 s with an acceleration of 5.00 m/s². If it continues to rise until its velocity is zero, what will be its maximum height?
    2. Relevant equations
    I thought I had to use the "UNIFORM MOTION with CONSTANT ACCELERATION" formula, which is d=vi*t+(1/2)*a*t²
    d = distance
    vi = initial velocity
    t = time
    a = acceleration
    3. The attempt at a solution
    d = 0*3.5+(1/2)(5.00 m/s²)(3.5)²
    I am not sure whether I set up the problem correctly or not.
  3. Aug 24, 2009 #2
    drizzle
    hey cyspope,
    what's the velocity of the rocket after 3.50 s? use this velocity* to determine the extra displacement, [this will be the initial velocity vo], you may use the velocity & displacement equation.
    * note the rocket will be decelerating under the effect of g = 9.8 m/s2 till the velocity reaches zero.
  4. Aug 24, 2009 #3
    It doesn't says about the velocity of the rocket after 3.50 s. and How would you apply the gravity, which is 9.8 m/s² into the equation?
  5. Aug 24, 2009 #4
    drizzle
    hint:
  6. Aug 24, 2009 #5
    drizzle
    don't forget, there're two different displacements, d1 [which you can calculate using the first part of the question], and d2 [as described above]. the maximum displacement [height] is then d1+d2
  7. Aug 2, 2011 #6
    Is the answer 63.125 m?
