Is Displacement Ventilation a Viable Option for Cooling in the Northeast USA?
In summary: I am currently working on the Displacement ventilation project and looking on the ways to arrive this 65deg Supply air temp. thru bypass of the air. Do anybody know the details of the calculations.
Artman
1,512
36
Any of you HVAC guys/gals design a Displacement Ventilation (DV) system in the Northeast USA?
With our heating requirements as a notable concern, is DV a viable option for very many applications in the NE USA (DE, NJ, PA areas).
It looks interesting to me especially for cooling, but I think adequate heating may be a concern. Anyone have any experience with it?
Here's a link to a http://www.price-hvac.com/catalog/J_all/SectionJ.aspx?pageRequest=INTRODUCTION" I found on the subject. It seems DV is geared more to cooling dominated spaces.
If a data center system qualifies, then I have...but as you say, that's a cooling only system.
Hi, Artman. I'm not sure what you're trying to accomplish. I've done HVAC work in FL, LA, NV, and CO, on a contractual basis.
I think the difference between data center cooling and what I am talking about is that the objective of DV is to not interfere with natural stratification of air, but to enhance it. DV seems to use lower velocity to avoid entraining and mixing old air with air being introduced through the HVAC system. Also, it uses higher, slightly below room temperature air (min of 65 deg F).
mugaliens, I don't currently have a project that suits this type of system on the boards, just researching it now. The areas you mentioned seem well suited to it. You should check it out.
DV systems, from what I read, can use 25% less outside air, because of more efficient distribution and resulting increased IAQ. And the higher delivery temperature air requires less energy to produce. It seems like an interesting system if it can be made to work in heating mode for my area.
Bingo, and not "seems to," but definitely. It's a minimal flow rate system designed for large spaces (think of movie theaters, warehouses, and older gymnasiums, particularly those in hotter climates), and requires natural stratification to be effective. The reason it uses below normal room temp air is to ensure that air from contamination sources (people, equipment) rises to the upper levels where it's extracted.
It works for cooling, but not for heating, as hot air rises!
Some areas in the NE can use it, but again, it's a cooling system, not a heating system.
Er... It's not a heating system. Again, it's for large spaces, and requires stratification, whichis disturbed by heating.
What is displacement ventilation?
Displacement ventilation is a type of HVAC system that delivers fresh air into a space at a low velocity near the floor, while extracting stale air from the top of the room. This creates a natural flow of air that improves air quality and thermal comfort.
How does displacement ventilation work?
In displacement ventilation, fresh air is supplied through low-level vents and allowed to mix with the warmer, stale air in the room. This mixture then rises and is extracted through high-level vents, creating a natural flow of air. This method is based on the principle that warm air rises, and allows for better air distribution and lower energy consumption.
What are the benefits of displacement ventilation?
Displacement ventilation has several benefits, including improved air quality, thermal comfort, and energy efficiency. It also creates a quieter and more comfortable environment, as the low velocity air supply does not create drafts or noise.
What types of spaces are best suited for displacement ventilation?
Displacement ventilation is most effective in large, open spaces with high ceilings, such as auditoriums, classrooms, and offices. These spaces can benefit from the natural flow of air and improved air quality provided by displacement ventilation.
Are there any limitations to displacement ventilation?
While displacement ventilation has many benefits, it may not be suitable for all spaces. It may not work well in spaces with low ceilings, high occupant densities, or where the source of pollutants is near the floor. It also requires careful design and maintenance to ensure proper air distribution and effectiveness.
  • Mechanical Engineering
  • STEM Career Guidance
64K
  • Art, Music, History, and Linguistics
  • Mechanics
10K
  • STEM Academic Advising
