Is Dissolved Air in Water Still Considered a Gas?
  • Thread starter strid
  • Tags
    Air Water
In summary: Air dissolved in water is in the LIQUID phase. Got it?Air dissolved in water is in the LIQUID phase. So, if you want to model the compressibility of air in a particular liquid, you would need to measure the compressibility of air in that liquid and use that value in your model.
strid
77
I have a question regarding a project I am working with currently...
Air that is dissolved in water (there always is around 0,004% I think, in normal pressure and 20 degress celsius), is it "physically dissolved"? I mean is the dissolved air still gas or is just air-molecules "trapped" between water molecules?
The essential reason for my question is to know whether the dissolved air affects the compressibility of the water, as air-bubbles definitely do, but I don't know about dissolved air.
I can give more information about the project if it's neccesary to fully understand my question...
From what I know, "dissolved gas" means gas trapped within the water molecules. Despite the general chemical definiton of the solute having to be ionized.
I believe this is true because fish are able to extract oxygen from water, and they don't perform and chemical reaction with the water in order to retreive this oxygen. In addition, the recent diffusers that are able to extract air from water work on henry's law, which is nothing chemical.
but is it still gas? is it tiny tiny bubbles?
and then, would it affect the compressibility...
Yes, still as a gas. The same way you have carbon dioxide in your coke. And in a reciprical manner, the same way you have water vapor in air. Well, I don't know about that, but actually as you try compressing the liquid, it will be capable of dissolving larger quantities of gas. As you decompress it, you will see gases bubbling out as a result of a lower soluability.
Let's not make up definitions of "solution" as we go along, shall we? Solution: a SINGLE phase homogeneous mixture of two or more components. There are NO constraints regarding ionization.
Does it affect compressibility? Yes. ALL solutes affect the compressibilities of all solutions.
What's the sign of the effect? Depends upon the partial molal volumes of the solutes and solvents; net decrease in volume forming the solution favors increasing solubility with increasing pressure.
Isn't there a net decrease in volume when dissolving air in water at STP?
Couldn't tell you --- the partial molal volume of air in aqueous solution isn't something I know off the top of my head --- it could be positive, it could be negative, or it could be so close to zero as to be negligible. It is possible to dissolve gases in solvents, increase pressure on the liquid phase and have bubbles form as the gas is driven from solution.
so you say that the air is liquid? Sounds interesting... But doesn't the temperature of air has to be quite low in order to be liquid??
Also, would it be valid to do the following:
Lets say we have the compressibility of air (C.a) and the compressibility of water (C.w)... If we are given that the fraction of air (R) dissolved in a glass of water would this equaton be valid?
Compresbility of the liquid = R * C.a + (1-R)* C.w
The slight problem in this formulation is that the value of C.a is when air is gas, which might affect...
EDIT: and of course, we are asuming that the air is evenly spread out in the water...
Well that makes sense, each substance has various conditions depending on its density, gas or liquid or solid...
But gases are liquids are considered fluids..So air can dissolve into water or liquids or substances in a liquid state.
Like when oxidating a metal in a liquid state for example..
strid said:
(snip)Compresbility of the liquid = R * C.a + (1-R)* C.w
(snip)
Use partial molal compressibility, or some other composition variable, and the composition, and your equation is correct. The trick, of course, is getting values for compressibility. For water and air, one measures the compressibility of the solution, compares it to that of pure water, and backs out the compressibility of air, or more specifically, of the various components. No, they are not the same as those of the gases at the same T, P.
so how wring would it be to assume that the air in the glass has the same compressibiliity as the air around us. Would it be valid for making a simplified model..?
Very, vveerryy, vvveeerrryyy wrong. Compressibility of an ideal gas, decent approximation for air at conditions you say interest you, is -RT/(VP2), or 1/P (in atm); compressibilities of liquids far from the critical point, again, your conditions of interest (the state of dissolved air), are measured in tens of parts per million per atm, some 10-100 thousand times less than for gases.
What is dissolved air in water?
Dissolved air in water refers to the presence of tiny air bubbles that are dispersed throughout the water. These bubbles are not visible to the naked eye and are typically caused by natural processes such as waves breaking or by human activities such as aeration.
Why is dissolved air in water important?
Dissolved air in water plays a significant role in the health of aquatic ecosystems. It helps to regulate the amount of oxygen available for aquatic organisms to breathe and can also affect the temperature and pH of the water. It is also important for various industrial processes, such as water treatment and wastewater management.
How does dissolved air get into water?
Dissolved air can enter water through various processes such as diffusion, aeration, and turbulence. It can also be introduced through human activities such as industrial processes or through the use of aeration devices.
What are the effects of too much dissolved air in water?
Excessive amounts of dissolved air in water can lead to various problems, including reduced water clarity, increased buoyancy, and altered water chemistry. It can also have negative impacts on aquatic organisms, as they may struggle to regulate their oxygen intake and may experience stress or even death.
How is dissolved air in water measured?
Dissolved air in water can be measured using various techniques, such as dissolved oxygen sensors, gas chromatography, and spectrophotometry. These methods allow scientists to accurately determine the amount of dissolved air present in a sample of water.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanics
  • Chemistry
  • Classical Physics
