Finding the Shortest Distance between Skew Lines
  • Thread starter nameVoid
  • Tags
    Lines
In summary: When you have done that, then I can show you how to find the shortest distance.In summary, the shortest distance between two skew lines is measured along a straight line and is equivalent to the distance between the two constructed parallel planes. The shortest distance is found by finding a vector perpendicular to both lines and taking the length of the cross product of this vector and the vector displacement between two points, given as <x, y, z>= <a, b, c>+ <d, e, f> t and <x, y, z>= <p, q, r>+ <u, v, w> s. This formula is advantageous as it only requires two points and two direction vectors
nameVoid
241
when trying to find the distance between 2 skew lines i see how we can take the a vector between points on each and the cross product of the direction vectors to find the distance but is this looks only to be the distance from one line to a particular point on the other
my question is if this is the shortest distance between the lines it does not appear to me that it is when using arbritrary points on each line
I see what you mean, you are correct, it won't be the shortest distance. The vector must be perpendicular to both lines to give the shortest distance. Can you think of a way to find a vector perpendicular to both lines?
It's not right ahead the minimal distance d between the lines g_1, g_2 you find by selecting those arbitrary points p_1, p_2 on each, you do this for getting representations of the parallel planes to be constructed:
A plane P can be described in many ways, one of them is
- a normal n
- and a fixed value λ, for which
<n,p> = λ (¹)
holds for all p ∈ P:
Given one point p in the plane for which <n,p> yields a certain value λ(p)
Now consider a second point q ∈ P:
The vector
r := qp
is parallel to the plane, thus it's orthogonal to n
<n, r> = 0
With
λ(q) := <n,q> = <n, p + r> = <n, p> + <n, r>,
the last "=" due to bi-linearity of <.,.>
one gets
λ(q) = <n,q> = <n, p> + 0 = <n,p> = λ(p).
So the, seemingly arbitrary, λ(p), we found is actually the plane-specific λ we've been looking for.
Because finding the minimal distance d between the lines g_1 and g_2 is equivalent to finding the distance of the constructed parallel planes p_1, p_2 , one gets for d
d = abs(λ_1 - λ_2),¹For shortness sake, I do not distinguish points from vectors here
The "shortest distance between two lines" (also know as the distance between the two lines. When we have regions that have more than one line between them, by "the distance" between them we typically mean the shortest distance between them) is measured along the line perpendicular to both lines. And that means that the line must line in the unique plane perpendicular to both.
As an example, suppose the lines are given by the equations x= t+ 3, y= 2t- 1, z= 3t and x= 2s+1, y= s- 2, z= s+ 4. Any plane perpendicular to the first line is of the form x+ 2y+ 3z= A, for some number, A, and any plane perpendicular to the second line is of the form 2x+ y+ z= B, for some number B. Find A and B such that those are the same plane and find the distance between the points where the two lines intersect each other.
so the cross product between 2 vectors is always perpendicular to both vectors but what about the length of this vector
No, the shortest distance between two points is a number. It is measured along a straight line. And the topic here is the shortest distance between to skew lines, not two points.
it would be obviously the shortest distance between two parrallel linesbut considering two skew lines where the distance varies
The length of the cross-product is not necessarily what you want.
You need to start by specifying the form in which the two lines are defined. Something like r00s0, r11s1?
The length of the cross product is not relevant. If you are given the two lines as <x, y, z>= <a, b, c>+ <d, e, f> t and <x, y, z>= <p, q, r>+ <u, v, w> s, then <a, b, c> and <u, v, w> are vectors in the direction of the two lines. Their cross product is perpendicular to both and so perpendicular to the plane you want to find.
Let's say you divide the cross product of the two direction vectors by its length to make at a unit vector ##\hat n## perpendicular to both lines. Then if ##P_0,\, P_1## are points, one on each line, and you let ##\vec V=\overline{P_0P_1}## be the vector displacement between the points, then the distance ##d## between the lines is$$
d =|\vec V \times \hat n|$$The advantage of this formula is that you are normally given two points and two direction vectors, and you don't need anything else.
[Edit] Typo alert, that should be ##d =|\vec V \cdot \hat n|##
<d, e, f> and <u, v, w>
if v=p0p1 then d=|v|cost=v.(axb)/|axb| now this is obviously the length of v is not going to be constant with arbtrary points
Please quote the post to which you are responding. It it's mine there was a typo. Still, what is your point?
As far as I can see, you have still not given an explicit statement of the vector form in which the two lines are specified. Is it a pair of points on each line? One point plus a direction vector for each line? Something else?
well we have p0 and p1 as points on each line and vectors a and b as directions
OK, so you can use the formulae LCKurtz gave you. But LCK was using P0, P1 as labels, not vectors, hence gave the vector form of the line joining them as ##\overline{ P_0P_1 }##. If you have p0, p1 as vectors, what will you write instead?
now this is obviously the length of v is not going to be constant with arbitrary points
Why not? See what happens if you replace p0 by another point on that line, p0+at.
length of v is not constant where v is the vector between points d=lvlcost
the example in the book takes parameter 0 for both lines but again i do not understand how this distance is the shortest distance considering that d is proportional to v
nameVoid, could you please quote the post you're replying to? It's a lot easier for us. Just hit "quote" on the right-hand side.
lvlcost
It is not proportional to the length of ##v## because there is a ##\cos t## in the formula.
Look at the picture. It doesn't matter which vector across between the lines you use. They all have the same projection on the normal direction (dashed) which gives the distance between the lines.
v.(axb)=lvllaxblcost
d=lvlcost=v.(axb)/laxbl
I give up. You won't quote the post to which you are replying and you just spout formulas as if that is some kind of conversation. Not with me. I'm gone.
ok you are telling me that the scalar projection of v onto axb is not equal to lvlcost
Using cos t isn't going to tell you anything because you don't know what t is. Stick to the vectors.
1. Write v as a function of p0 and p1
2. Consider an alternative definition of the first line using p0'=p0a instead of p0. Write the corresponding v'.
3. Expand v'.(axb) and compare it with v.(axb)
if you are trying to tell me that the distance is not affected by the length of v then you are telling me that v along axb is not equal to lvlcost
ld=lvlcost
ldl=lvlcost
No, I'm telling you that if you replace, say, p0 by a different point on the line p0+aλ then the vector v defined by p0 and p1 will change in both magnitude and direction. It will change in such a way that d does not change. But don't take my word for it, follow the steps I've laid out for you and see for yourself.
I shall post no more on this thread until you have posted an attempt to do so.
  • #31
ok so it seems to be consistant so there is only one lunit vectorl which is perpendicular to both lines and therefore the shortest distance must be in this direction i believe that this can be understood by taking all vectors to the origin and then raising one direction vector away from the other you will see that the shortest distance is along the cross product vector in a way its raising the point of intersection and then meaduring the distance
1. What are skew lines?
Skew lines are two lines in three-dimensional space that do not intersect and are not parallel. They are also known as oblique lines.
2. How do you find the shortest distance between skew lines?
The shortest distance between skew lines can be found by finding the distance between any two points on the lines that are closest to each other. This can be done using the formula for distance between two points in three-dimensional space.
3. Can the shortest distance between skew lines be negative?
No, the shortest distance between skew lines cannot be negative. It is always a positive value, as it represents the length of the shortest path between the two lines.
4. Are there any special cases in finding the shortest distance between skew lines?
Yes, there are two special cases. One is when the two skew lines are actually parallel, in which case the shortest distance between them is the distance between any two points on the lines. The other case is when the two skew lines are actually the same line, in which case the shortest distance between them is 0.
5. Is there a visual representation of finding the shortest distance between skew lines?
Yes, there are several visual representations, such as using a 3D graph or a geometric diagram. These can help in understanding the concept and finding the shortest distance between skew lines.
