Distance Between Two Slits
  • Thread starter JSapit
JSapit
34
Light of 650 nm is incident on two slits. A maximum is seen at an angle of 10.93degrees and a minimum of 11.73degrees. What is the order m of the maximum?
What is the distance d between the slits?
dsin(theta)=m(lambda) - max
dsin(theta)=(m+1/2)(lambda - min
So I started out with the two equations, one for the constructive interference and destructive interference. I solved one equation for d, and then substituted that solved equation into the other to try and find m. I don't know if it was an error in math or what, but I can't seem to solve this problem. Is there an easier way that this, or is this the easiest?
P.S. Sorry I've posted three threads for three different questions, but I'm having trouble with this chapter. Thank you for your patience and your help.
Answers and Replies
Delphi51
3,407
It sounds good to me. I wrote the two equations
mL = d*sin(A) and (m+.5)L = d*sin(B) and divided them to eliminate the d.
This almost resulted in a whole number - one % off. Close enough, I guess.
JSapit
34
What did you get for your m? I took an m out after I divided the two equations, so it looked like m=(.5sinA)/sinB, which got me about .466330. I tried entering it and it wasn't right. My math is definitely wrong ._.
Delphi51
3,407
Dividing the 2 equations, I got
1 + .5/m = sin(B)/sin(A) = 1.072203
so .5/m = .072203
m = 6.92
JSapit
34
That explains what I did wrong. I figured it out. Thanks for all your help Delphi!
knyoung
Woohoo
Suggested for: Distance Between Two Slits
  • Last Post
  • Last Post
  • Last Post
