• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Distance, displacement
1. Homework Statement
A particle's position is described by x=2t^3-4t-5
Find its a) displacement b) distance
from t=0 to t=5
2. Homework Equations
3. The Attempt at a Solution
Displacement, plug in x(5)-x(0) = 230m
Distance, shouldn't it be the same thing plug in and get 230m? But book says 234m. No idea how this came about.
296
Hey ,
Do you know the difference between distance and displacement (Am sure you do! :-))
If a particle goes from x = 2m to x=4m and then comes back to x=3m
What is the distance travelled and displacement?
How did you calculate it in simple terms.
Something similar is happening here.
distance would be the actual physical length, so that would be 3m. Displacement is just the direct distance from start to finish, so that would be 1m.
296
Yes.So the basic logic you used is that you added the path length.
When the body reversed its direction at 4m ( in physics what is this point signify in terms of variables?) you didn't add the path from 4m to 3m as -1m.You added it as 1m.
Do the same on this question and you will get the answer:-)
alright man but ur concept was a simple question, this one has complicated equations and i don't know how to apply it : ======================== (
296
Ok.
See displacement is integration of (vdt).
Distance is integration of (|v|*dt)
And |v| is speed.
For solving the mod || you need to find intervals where v is positive and where v is negative.
so take absolute value of x=2t^3-4t-5.
then it would be -2t^3+45+5
so i take the integral of this and that's it?
296
For what value of t is the velocity positive?
When is it negative ?
take the negative of v where velocity is negative.
Take positive when velocity is positive.
Then integrate.
(Why do we do so?)
ok, so when x=0 is the difference. So x is negative the function is: -2t^3+4t+5, and when x is positive the function is: 2t^3-4t-5
add these two up and integrate?
but if i add it up i get 0?
296
No.We are interested in mod of velocity not x.take function as it is when v is positive(not neccesarily x) and multiply by minus when v is negative (not x)
296
No.We are interested in mod of velocity not x.take function as it is when v is positive(not neccesarily x) and multiply by minus when v is negative (not x).
And you wont get 0.
hey can you just show me the process? I'm getting very confused and I'm not sure what's going on. I think I can understand better if you show me the math. velocity would be x'=6t^2-4
Thanks man.
296
Thanks man.
You calculated the velocity correctly. :-)
Property of mod function is that
when f(x) is positive
|f(x)| =f(x)
when f(x) is negative
|f(x)| =-f(x).
For eg if |2| is 2.|-2| is -(-2) i.e 2 again.
Velocity is 6t^2-4.
which is positive when t belongs from sqroot (2/3) to 5 and negative between 0 to sqroot(2/3.)
So take displacement of [-(2t^3-4t-5)] for t = 0 to t=sqroot(2/3).
(or you can integrate
[-(3t^2-4)dt]
And take displacement of [(2t^3-4t-5)] for t=sqroot(2/3) to t=5.
[(3t^2-4)dt]
how did you get sqrt(2/3)??
I guess that's from x=2t^3-4t-5??
so 0=2t^3-4t-5
But how do I solve this cubic equation???
Thanks a lot man.
296
From 6t^2 -4 >0
We are interested in |v| not mod x.
See in the example i gave you .
From 2 to 4 m velocity was positive so you did 4-2 =2
(final position -initial position)
Then particle turned behind and velocity became negative.in moving from 4 to 3 you therefore did -(3-4)=1
And added these.
All this while x was positive.
Our sense of mod depends on velocity and not position :-)
My pleasure :-)
I hope am making stuffs clear enough :-)
Hopefully
thanks a lot man europeans are superior
296
Lol. I am an Indian :-)
Related Threads for: Distance, displacement
  • Posted
37K
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
