Why is the distance always greater than or equal to the displacement?
In summary, the distance traveled can never be less than the displacement because the displacement is always the shortest possible distance between two points. This can be seen through the example of traveling around a circle, where the distance traveled is greater than the displacement. Mathematically, distance is the sum of non-negative quantities while displacement is the magnitude of a vector, making it always greater or equal to distance. Additionally, displacement represents the shortest path between two points, so nothing can be shorter than it.
jacyh
Why is the distance never less than the displacement?
I can't seem to find a scientific explanation for it. :confused:
think about traveling half way around a circle, the distance traveled would be half the circumference, and the displacement would be the diameter.
in this case distance > displacement
distance can be equal to the displacement (if you travel in a straight line), but it can never be less.
I know, but... why? Haha.
just think about the example i gave you and think of any other ones you can think of... the displacement will never be greater than the distance.
Think of distance as "distance travelled"
So if you're going from point A to point B in any situation you can think of (around curves, over mountains etc...) The distance traveled will be greater because you had travel "around" things.
The displacement is a straight line between point A and B, so it is always the shortest possible distance.
Strictly speaking, distance is a magnitude but displacement is a vector.
So, yoiu really mean
"why is distance >= magnitude of displacement ?"
Mathematically,
[tex] \int \left| d\vec s \right| \geq \left| \int d\vec s \right| [/tex]
Essentially, distance [ the arc-length of a curve from A to B ] is the sum of non-negative quantities.
The magntude of displacement [ the magnitude of a vector from A to B ] is the non-negative magnitude of a sum-of-(signed)-vector-quantities.
The proof of the inequality is essentially the triangle inequality.
distance is total distance traveled, displacement is from the initial location to the final location.
The displacement is the shortest way possible from the start to the finish (that is, it's a line); thus, nothing can be shorter.
What is the difference between distance and displacement?
Distance refers to the total length of the path traveled by an object, while displacement is the shortest distance between an object's starting and ending point.
Can distance be greater than displacement?
Yes, distance can be greater than displacement if an object takes a longer path to reach its final position.
How are distance and displacement related?
Distance and displacement are related in that distance is a scalar quantity, while displacement is a vector quantity that includes both magnitude and direction.
Is displacement always positive?
No, displacement can be positive, negative, or zero depending on the direction of motion. Positive displacement indicates motion in the forward direction, negative displacement indicates motion in the opposite direction, and zero displacement indicates no overall motion.
In what situations is displacement equal to distance?
Displacement is equal to distance when an object travels in a straight line without changing direction. In this case, the shortest distance between the starting and ending point is also the total length of the path traveled.
