Distance of ions from photographic plate
  • Thread starter Thread starter sarahaha288
    Ions Plate
The discussion focuses on calculating the distance of ions (N2+, O2+, NO+) from a photographic plate after completing half an orbit in a magnetic field. The relevant formula used is R = mvq / (qB), where R is the radius of the orbit, m is the mass of the ion, v is the velocity, q is the charge, and B is the magnetic field strength. The user initially miscalculated the distance due to incorrect assumptions about the radius, realizing that the ions would actually hit the plate at a distance of 2R from their starting position.
  • Understanding of ion motion in magnetic fields
  • Familiarity with the formula R = mvq / (qB)
  • Knowledge of atomic mass conversion from amu to kg
  • Basic principles of electromagnetism
  • Review the derivation of the radius of curvature for charged particles in magnetic fields
  • Learn about the effects of varying magnetic field strengths on ion trajectories
  • Explore the concept of charge-to-mass ratio in particle physics
  • Investigate the implications of half-orbit calculations in practical applications
Students in physics or chemistry courses, educators teaching electromagnetism, and researchers interested in ion behavior in magnetic fields.
sarahaha288
How far would the spot on the photographic plate be from the entry point for each ion, assuming that each ion completes half an orbit?
I am given three ions, N+subscript2, O+subscript2, NO+
They have atomic masses of N=14.0031amu and O=15.9949amu.
I am given the magnetic field strength=8.5MN/C
velocity=30.0km/s
The magnetic field is uniform and perpendicular to the velocity.
I tried to use R=mvc/ qB
q is the charge, m=mass, v=speed, c=speed of light, B= magnetic field strength
I tried simply substituting these in and using the standard 1.60*10^-19C for the charge. For the mass i just took the atomic mass, multiplied it by the subscript of two for the first two and then converted it to kg.
I got it wrong.. and i can't tell why.
If i could just figure out what i did I'm pretty sure it's the mass or the charge that is incorrect but i have not had chemistry in quite awhile and can't figure it out...
Thanks for all your help in advance!
Think about it more. Do the ions really hit the plate 1 radius away from their starting position?
No. I think it's 2R now. Thank you... I'm not sure how i overlooked that.
10K
  • · Replies 46 ·
