Distance problem
  • Thread starter vac
vac
28
A 50,000 kg locomotive is traveling at 10 m/s when its engine and brakes both fail.
Known
Vi= 10 m/s
Vf = 0 m/s
mass = 50,000 kg
_______________
Find distance
How far will the locomotive roll before it comes to a stop? Assume the track is level.
F = ma
[tex]a = \frac{0-10}{0-t}[/tex]
[tex]v_f = at+v_i t[/tex]
[tex]0 = \frac{0-10}{0-t}t+10 m/s t[/tex]
after using distance formula, my answer is 29.8 m
Answers and Replies
Delphi51
3,407
Welcome to PF, vac!
The problem is not solvable without further information. If the train has lots of friction, it will not go very far. If it is well oiled and the track is excellent, it will go a considerable distance before stopping. So no answer unless you know the coefficient of friction or something related like the deceleration or the time to stop.
vac
28
This is the question that supposed to have all the information: "A 50,000 kg locomotive is traveling at 10 m/s when its engine and brakes both fail. How far will the locomotive roll before it comes to a stop? Assume the track is level."
Also the answer in the back of the book is 2.6 km
I don't know how they got that answer. Now I am thinking they used [itex]F_k = u_k F_N[/itex]
[itex]F_k = ({rubber~~on~~~~concrete~~} u_k = 0.80 ) F_N[/itex]
[itex]F_k = 0.80 F_N[/itex]
lep11
380
Doesn't locomotives usually run on rails?
Delphi51
3,407
Ah, you can look up the coefficient of friction! Wouldn't it be steel wheel on steel track? The friction force causes the train to decelerate. Calculate the acceleration and then you just have an accelerated motion problem to solve for the distance.
I must add that this thinking is not really correct; the kinetic coefficient of friction between track and wheel would only apply if the wheel was locked and sliding on the track. When rolling with no braking, the friction involved would be air resistance and friction of the moving parts in the bearings which you have no way to calculate. However, the writer of the problem may be thinking of it just the way you are - work it out and see if you get the "correct" answer.
If you haven't posted the complete wording of the problem, please do so!
SteamKing
Staff Emeritus
12,798
1,670
And they use steel wheels to boot.
SteamKing
Staff Emeritus
12,798
1,670
lep11
380
Indeed. I thought it'd be obvious since I already mentioned the rails . But anyway the coefficient will be much smaller than 0.8.
Delphi51
3,407
lep11, does your marker appreciate students going a little further than necessary?
If so, you could begin with the given answer and work backward to find the coefficient of friction.
Then use that coefficient to work the problem through to find the stopping distance.
vac
28
I think it is steel on steel so [itex]F_k = u_k F_N[/itex]
[itex]F_k = ({steel~~on~~steel~~(dry)~~} u_k = 0.60 ) F_N[/itex]
[itex]F_k = 0.60 F_N[/itex]
I still get the wrong answer though. Any ideas?
Delphi51
3,407
0.6 is a tremendous coefficient of friction! I calculate that the train will stop in 1.7 seconds, as it goes distance 8.49 meters. I guess that is not what the creator of the question had in mind.
Steam King's link has 0.010...0.035 for a car on a road; something in that range would be reasonable.
You might take a guess somewhere in there and run it through again. Or work backward from the correct stopping distance to see what the coefficient needs to be to get the right answer.
Actually, if most of the marks are for the work, we should concentrate on getting your calculation right regardless of the value for u or the distance. Did we agree on 8.49 meters for the u = 0.6?
SteamKing
Staff Emeritus
12,798
1,670
The coefficient of resistance for a steel wheel on a rail is 1 to 2 orders of magnitude smaller than the resistance of a car on a road, according to the link in post #7.
Delphi51
3,407
The thing is, it ISN'T steel SLIDING on steel. It is steel rolling on steel plus air resistance plus bearing and gear frictions. The question writer should have put it in the question (or if it is from a book, the coefficient should be in the chapter preceding the question).
See slide 21 here for a description of how rolling friction occurs with train wheels
This problem was taken from slide 23. It assumes you saw slides 21 and 22 where the u is given.
http://www.docstoc.com/docs/134983793/PowerPoint-Presentation
sunnnystrong
54
I understand this question is very old but the coefficient of static friction for rolling friction for steel on steel is 0.002 (given in the book).
Solution:
Friction = 0.002*(490,000 N) = 980 N
F = m*a -->
-980 N = 50,000kg * a
a = -0.0196 m/s/s
Solve for distance:
V^2-Vo^2 = 2a(X-Xo)
X-Xo = 2.6 km
Suggested for: Distance problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
