Diverging lens on filament
  • Thread starter songoku
166
A diverging lens with focus 5 cm is placed on a filament. Find the distance between the lens and the filament
[tex]\frac{1}{f}=\frac{1}{di}+\frac{1}{d}[/tex]
Focus of diverging lens is negative so, f = -5 cm. I think the question is asking about di. What is d ? Can it be infinity because the filament gives light until far enough distance ?
Thanks
Answers and Replies
Maroc
From what i recall di = initial distance of object and d is the final. However, to solve your question i won't be as much as of a help as others. Sorry.
166
Hi Maroc
Ah thanks for clarifying my equation. I usually use d as distance of object and d' as distance of the image. I think it's better to use your notation.
Maroc
No problem songoku,
Just like to help around. If there is no help here try wiki or other info sites regarding this matter.
rl.bhat
4,433
If you real positive sign convention,
the equation becomes
-1/f = 1/do + 1/di, where do is the object distance and di is the image distance.
Here do = f = 5 cm
166
Hi Mr. rl.bhat
Why does do = 5 cm ? Based on your equation, I think the question is asking about do, the distance between the lens and filament.
Thanks
Maroc
Hi Mr. rl.bhat
Thanks
he rearranged the equation to get 5cm
166
Hi Maroc
Oh I see. So like I said, di (the distance of image) = infinity, right ?
Thanks
rl.bhat
4,433
Hi Maroc
Thanks
In the given problem there are two unknowns. By a diverging lens you cannot get an image at infinity. So I thought the object is at the focus of the diverging lens. In the MCQ most of the students will select the image at infinity, which is wrong.
166
Hi Mr. rl.bhat
Oh I see. The image of diverging lens should be located between the focus and the center of the lens.
But I don't understand why you thought the object is at the focus. I think it's possible the object (in this case I suppose the object is the filament) is located between f and 2f or further than 2f and the question is asking about this distance.
Thanks
ideasrule
2,271
I'm confused. The question says that the lens is placed on the filament, then asks for the distance between the lens and the filament? If one is on top of the other, wouldn't the distance be 0?
166
Hi ideasrule
I'm not sure about that, but that's the question. Or maybe the lens is placed in front of a filament in a lightbulb?
Thanks
Related Threads on Diverging lens on filament
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
17K
