Diving bell
  • Thread starter diva8789
An evacuated spherical diving bell containing a camera is in the ocean at a depth of 121 m. It has a flat, transparent, circular port with a diameter of 19.7 cm. Find the magnitude of the total force on the port (use ρseawater) = 1025 kg/m3).
P(total)= ρgh+P(atm)
A=[tex]\pi[/tex]R^2
I know that you need to find the total pressure on the bell. And then i think you have to subtract that total pressure from atmospheric pressure. this is what i have been doing and it is not working correctly. does anyone have any ideas?
Thanx!
Answers and Replies
Shooting Star
1,977
Force = pressure x area. You know the pressure of the water at that depth, since density is known. Rest is easy. Atm presssure may be neglected.
Dick
26,260
619
Just to amplify what Shooting star is saying, the reason you can neglect atmospheric pressure is not because it is terribly small. It's about ten percent of the seawater pressure, but because you should probably assume there is also atmospheric pressure inside of the bell, so it cancels. Just use the rhoseawater they gave you together with the area.
Total force on the port:
pressure/area from seawater on one side
pressure/area from 1atm on the other side
Shooting Star
1,977
Hi Dick,
The problem specifically states that the sphere has been evacuted. So, inside is almost vacuum.
To be realistic then, P_atm should be added to the water pressure, since 1/10 of the water pressure is not really negligible.
Dick
26,260
619
Hi Dick,
In that case, yes, it should. Sorry, I should read more carefully!
Related Threads on Diving bell
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
