Chemical/Paint DIY Sabatier Reactor
  • Thread starter CCatalyst
Summary
Fighting climate change while making money at the same time.
We all are aware of the looming danger of climate change and so I want to do my part. I plan to capture the carbon dioxide from the air using magnesium oxide, turning it into magnesium carbonate, and then heating it up to reverse the process while capturing the carbon dioxide. The Sabatier reactor is quite simple, just a tube made of nickel that can handle the heat and pressure. Then is where the tricky part comes in, the water and methane enter a chamber with high temperature and low pressure. Here I want to use heat to break down the methane and let the carbon settle at the bottom. The difficulty comes with dealing with the water. I guess I will let it vent out towards the external burner used to break the methane inside down along with the extra hydrogen as it is interacting with atmospheric oxygen. I will attempt to use electricity to recapture the hydrogen and reuse it for the cycle while releasing as much as the oxygen as possible. However, I'm not sure how high of temperature an electrolyzer can operate at.
I know this will take electricity to run, but I plan to buy a solar-charged battery pack. The real hard part is integration and parts compatibility. I don't want to spend a lot of money on something just to find out it cannot work with other parts. As for the carbon, I plan to sell it.
Also, I would like to keep this simple, this way many people could do this. Any questions or suggestions?
275
121
Magnesium oxide-based carbon dioxide capture generally too problematic at industrial scale due sluggish kinetics and high recycling temperature; NASA do use manganese oxide for carbon dioxide scrubbers though.
691
If I take that right you plan to invest a lot of energy to capture carbon dioxide (save the planet) and then sell the carbon - which then will be likely burned? o_O
I think selling the methane instead would be a bit less disastrous financially. But not by much.
Just selling the output of you solar power would work. That would also at least make a (slightly) negative carbon balance. Maybe.
24
I do not want to sell the carbon to be burned again, I want it to be used to build stuff, like carbon fibers.
Also, I cannot find a lower temperature regenerative carbon dioxide scrubber than magnesium oxide. Besides, if I were to use manganese it would release the even MORE dangerous carbon monoxide.
Any more suggestions?
275
121
Add catalytic filter with counter-flow reheater at manganese-based scrubber output if you are concerned with CO emission; Space Shuttle manganese-based scrubbers did not emit CO though.
Or use ethanolamine scrubber.
Actually i understand what all existing CO2 scrubber technologies, especially ones which use natural air as input, are either extremely bulky or require expensive material input. It would be a challenge to develop a technology clearly superior to bioreactors or trees.
Also, carbon fiber is not made of bulk carbon - you need either coal tar or PAN plastic as input.
anorlunda
Mentor
Insights Author
4,079
If you want to capture carbon and have something to sell to build things, plant a tree.
Almost all the weight of a dried tree is captured carbon.
275
121
To be exact, dry cellulose can be decomposed as 44% carbon and 56% water.
1,334
691
In short: the efficiency is so low and the necessary equipment is so complicated, that it will inevitably end with a terrible carbon balance. Having released ten times of carbon compared to the 'captured' amount might still be an optimistic assumption.
I do agree with @anorlunda : if you want to save the planet, then rather plant a tree.
If you want to have fun with a small scale DIY project, then we are happy to keep you company here.
TeethWhitener
769
Also there's a ton of work being done on artificial photosynthesis/photoelectrochemical reduction of CO2 for fuel synthesis.
24
Every time I am given an alternative to magnesium oxide, I am recommended something that is more complex and dangerous.
The hard part right now for me is to find nickel tanks that I can take apart before and after use. Where do I go to buy a small one of those?
anorlunda
Mentor
Insights Author
4,079
Summary: Fighting climate change while making money at the same time.
Let's start with the basics. How many pounds of carbon per year do you need to capture to declare it a success?
Bystander
1,074
..., and how many tons of air, @400ppm, do you need to process to achieve that target? Can you pump it across the room for the energy you produce?
TeethWhitener
769
...it almost sounds like you’re asking us not to help you.
If all you want to do is fix carbon, just do it electrochemically. You can use a 9V battery and a platinum wire. If you want to do it efficiently, well...take a look at the work of the thousands of researchers trying to do just that. I gave you two examples of that.
Want to reply to this thread?
"DIY Sabatier Reactor" You must log in or register to reply here.
Related Threads for: DIY Sabatier Reactor
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
