Do I need to know the height to solve this?
  1. Jun 26, 2011 #1
    When a 5kg mass is hung vertically on a light spring the spring stretches 3 cm. how much work must a external agent do to stretch the spring 4 cm from its equilibrium position?
    Because I am guessing it is hung vertically from the ceiling?
  3. Jun 26, 2011 #2
    fluidistic
    No you don't need the height.
    Yes it's hung vertically from the ceiling. I'll give you a hint to solve the problem: consider the potential energy stored in a string.
  4. Jun 26, 2011 #3
    Why don't you need to know the height? Isn't there gravity? I know that it is just
    [tex]\int_{x_0 = 3cm}^{x = 4cm} -kx dx[/tex]
    But I am sure that I need gravity
  5. Jun 26, 2011 #4
    You need the acceleration due to gravity, with varies do little with height that it is treated as a constant 9.81 m/s2 near the surface of the Earth.
    Do you see how to calculate k from the given information?
    Also note that the question asks for the work done stretching from the equilibrium position to 4 cm. The integral you posted is inconsistent with that.
  6. Jun 26, 2011 #5
    fluidistic
    This is right.
    Although I do find the wording of the question confusing. When they say
    , do they mean equilibrium position when there's the mass attached to the spring or when the mass isn't attached yet? Because if it is the former then flyingpig is right, I believe.
  7. Jun 27, 2011 #6
    [PLAIN]http://img824.imageshack.us/img824/403/hieh.jpg [Broken]
    I need to know height, this is a picture of how I interpret the problem
  8. Jun 27, 2011 #7
    Let me rephrase the question. This might make it clear what the question is asking.
    How much work must a external agent do to stretch a light spring 4 cm from its equilibrium position? Oh by the way, when a 5kg mass is hung vertically on the spring the spring stretches 3 cm.
  9. Jun 27, 2011 #8
    That's how I was seeing it. The "by the way" clause let's you find k, and that then gets you an answer.
  10. Jun 27, 2011 #9
    fluidistic
    Ohhh... I see now. Personally I thought flyingpig had its limits of the integral right. So thanks a lot for the clarification.
    And who else agree with me when I say that flyingpig doesn't need the height? As long as g is treated as a constant, there's no need to know the height.
  11. Jun 28, 2011 #10
    What...?
  12. Jun 28, 2011 #11
    Read the posts after yours and point out the line which you do not understand.
  13. Jun 28, 2011 #12
    Isn't that what I did with my integral? BUt my integral is still only half completed.
  14. Jun 28, 2011 #13
    I see I was mistaken about the integral. At a glance I thought you were using it to find the work, but now I see that expression is intended to equal force. IN that case the limits of integration are correct.
  15. Jun 28, 2011 #14
    Although springs exert a nonconservative force, you can treat this problem as a conservative force problem for now. Conservative forces have a definite integral and a potential energy graph. Thus, you need to know the height when using the ever easy equation of potential energy equals mass times gravity times height. Just think about how you can apply the 2nd law of thermodynamics into this great and insightful setting!
  16. Jun 28, 2011 #15
    fluidistic
    Look at post #6. When you say "you need to know the height when using the ever easy equation of potential energy equals mass times gravity times height.", flyingpig might think he needs to know the value of d or h. And he doesn't need these values.
  17. Jun 29, 2011 #16
    Okkay, how about this, tell me why don't you need the height? Why is there no gravity in play? It's hanging vertically
  18. Jun 29, 2011 #17
    I suspect you are thinking about this differently than some of us, and the confusion is coming from that. Can you say how you would use the height if it were given? That should let us explain why it is not necessary.
  19. Jun 30, 2011 #18
    [PLAIN]http://img200.imageshack.us/img200/92/unledvx.jpg [Broken]
    [tex]\sum W = \int_{x_0 = 3\cdot 10^{-2}m}^{x = 4\cdot 10^{-2}m} -kx dx + -mg(5m - 6m)[/tex]
  20. Jun 30, 2011 #19
    Thanks for clarifying your approach.
    Here is the original question:
    The work done by the "outside agent" depends on the force he/she/it applies to the 5 kg mass. The -kx is the upward force exerted by the spring. The mg is the force exerted by gravity. Where is the force exerted by the outside agent?
  21. Jun 30, 2011 #20
    fluidistic
    I'm afraid this sketch is wrong. Seems like you mean that the weight of the mass stretched the spring 1 meter while this isn't true.
    Also we can see that 1cm=1m from the sketch.
    So now we interpret the problem as stretching the spring 4 cm from its equilibrium position (when there's no mass attached) when a mass of 5 kg is hanging from the spring?
