Can someone help me understand this?
  • Thread starter apples
In summary: This is driving me crazy. Part of my Calculus work. My graphic calculator says undefined.Does 0/0 and ∞/∞ = 1? But in my books, the way the solution is, it seems as if they do equal 1.I've learn L'hopital's rule, and this isn't related to that.In summary, 0/0 and ∞/∞ are undefined, but if you take the limit of x/x as x -> ∞ or 0, then it becomes 1.L'hopital's rule is what solves this problem.
apples
171
[SOLVED] Does 0/0 and ∞/∞ = 1 ?
What is the homework problem? Is it a limit that you are taking?
0/0 and ∞/∞ are undefined, but if you take the limit of x/x as x -> ∞ or 0, then it becomes 1, because they are approaching either ∞ or 0 at the same "speed", so they keep canceling each other out.
Have you learned L'hopital's rule yet? Look it up in your calculus textbook if you haven't, its very simple.
Yeah, that's what it's called. It's the general rule for the example I gave. Very useful.
No.
Well, you're going to have to give us the exact question, before we can help you. Is there any reason this is in career advice? I'm moving to one of the homework forums.
one problem is exactly what poop-loops said.
The limit is 0(right hand limit) though, and the x in the denominator is absolute.
OK, poop-loops, I kind of understand what you're saying.But here's another problem:
The question is
Determine whether the series:
∑ n/3^n
n=1converges.
We're supposed to use the ratio test.
After some simplifying we get
lim (n+1/n)(3^n/3^n+1)
n->∞
Now if we substitute ∞ the first bracket becomes ∞/∞.
The solution is 1/3. So in order for the second bracket to become 1/3 this should happen:
(1/3^n-n+1)
And it must be multiplied into 1. So ∞/∞ has to be 1.
I am so confused.
I am confused about your limit expression too..lol...
Can you rewrite it, it is not clear at which is numerator and which denominator, if there is one at first place!
P.S. Just use more parentheses
OK.
∑ (n)/(3^n)
n=1converges.
lim ((n+10/(n))((3^n)/(3^(n+1)))
n->∞
((1)/(3^(n-n+1)))
so i guess your limit is this
[tex]\lim_{n\to\infty}\left(n+\frac{10}{n}\right)\left(\frac{3^n}{3^{n+1}}\right)[/tex]
right?
n->∞
(1/3^n-n+1)
I am so confused.
You're taking a limit. You're not evaluating the equation AT n = ∞, you're evaluating it as it gets closer and closer to infinity.
So let's take (n+1)/n first. This is your first term. When n = 1, you get 2/1. When n = 100, you get 101/100. When n = 10000, you get 10001/10000. Etc. So when n gets REALLY big, the whole thing gets closer and closer to 1. At n = ∞ you basically ignore the 1 and just end up with n/n.
Now your second term, (3^n)/(3^(n+1)). If I'm not mistaken, you can right off the bat just cancel out 3^n on top and bottom and you end up with 1/(3^1), so there's your 1/3rd.
apples said:
The question is
∑ n/3^n
n=1converges.
Ok, so the ration test says to look at [tex]\left|\frac{a_{n+1}}{a_n}\right|[/tex] where here a_n=n/3^n.
n->∞
No. You get
[tex]\lim_{n\to\infty}\frac{(n+1)}{n}\cdot\frac{3^n}{3^{n+1}} .[/tex]
Simplify this (hint: can you write [itex]3^{n+1}[/itex] in terms of [itex]3^n[/itex] ?
Why do you think that's valid? Reread your limit rules.
No, the ratio test looks at the quantity:
[tex]\frac{\frac{n+1}{3^{n+1}}}{\frac{n}{3^{n}}}=\frac{1}{3}\frac{n+1}{n}[/tex]
I'm even more confused.
Let me reread everything.
(This isn't precal, it's AP Cal BC)
i'm sorry i mistyped the corrected function
my shift key isn't working properly so i put a 0 instead of )
Let me correct it again (sorry)Determine whether the series:
∑ (n)/(3^n)
n=1converges.
lim ((n+1)/(n))((3^n)/(3^(n+1)))
n->∞
((1)/(3^(n-n+1)))
Why do you think that is valid? Reread your limit rules. :tongue:
Surely you've done exercises where, rather than blindly substituting, you painstakingly applied the rules for manipulating limits to justify calculations. Try repeating that exercise here...
OK, I understood what poop-loops is saying. This answers my question:
arildno, I have no idea what you're trying to say.
cristo, i didn't understand the first part you wrote, but the second part where you corrected my equation is the equation i wrote.
I have the solution in front of me. this question was an example, but didn't give explanations.
Now I understand why (n+1)/n = 1
It's not though is it? You missed out crucial parentheses.
Put the example down. You need to work through it without the solution.
This is NOT true, in general. You mean that the limit as n tends to infinity is equal to 1.
Did you even bother thinking about the hint I gave you?
No. You get
yes, i did, and i thought it meant the second bracket would become 1/3
Sure, but why? You don't have to say, of course, if you are now happy with the solution.
Because the nth power in the numerator is subtracted form the nth power in the denominator.
(3^n)/(3^(n+1))=1/(3^(n-n+1))=1/3
:D
I already wrote that in one of my previous posts.
Anyway, thank you everybody for the clarification!
Please stop doing that! You have been told repeatedly that you cannot "substitute" [itex]\infty[/itex]] for a real number.
The limit of ((n+1)/(n))((3^n)/(3^(n+1))= [(n+1)/n](1/3) is 1/3. Surely you learned, long before you started using L'Hopital's rule, that you do NOT find a limit, as n goes to infinity, by "substuting" [/itex]\infty[/itex] for n.
Yes, as n goes to infinity, (n+1)/n goes to 1. Now what about (3n+1)/n? What is its limit as n goes to infinity? What do you get if you "substitute" [itex]infty[/itex] for n?
What is [itex]3(\infty)+ 1[/sub]?
What is the limit of n^2/n as n goes to infinity? n/n^2? n/n? This would seem to suggest that you can't "evaluate" an expression at infinity.
i've understood, but misused terms.
1. How can I better understand complex scientific concepts?
One way to better understand complex scientific concepts is to break them down into smaller, more manageable parts. Start by identifying the main ideas or key terms and then work to connect them in a logical way. Additionally, seeking out additional resources such as textbooks, articles, or videos can also aid in understanding.
2. What are some effective study strategies for understanding scientific material?
Some effective study strategies for understanding scientific material include creating study guides, practicing active reading by taking notes and summarizing important information, and utilizing visual aids like diagrams or charts. Additionally, discussing the material with others or teaching it to someone else can also help solidify understanding.
3. How can I improve my critical thinking skills in regards to understanding scientific information?
Improving critical thinking skills in regards to understanding scientific information involves actively questioning and evaluating the information presented. This can include examining the evidence and reasoning behind scientific claims, considering alternative explanations, and evaluating the credibility of sources.
4. Are there any resources available to help me understand specific scientific topics?
Yes, there are many resources available to help with understanding specific scientific topics. These can include textbooks, online articles, scientific journals, and educational videos. Additionally, reaching out to experts in the field or joining study groups can also be beneficial.
5. How can I overcome confusion or misunderstandings when trying to understand scientific concepts?
If you are feeling confused or have misunderstandings while trying to understand scientific concepts, it can be helpful to take a step back and approach the material from a different angle. This can include seeking out different explanations, breaking down the information into simpler terms, or seeking clarification from a mentor or teacher. It's also important to be patient with yourself and give yourself time to fully grasp the material.
