Does CO2 float?
  • B
  • Thread starter cps.13
This may sounds like a stupid question but...
If you were to use a subsea lifting bag filled with O2 it would rise to the surface.
Would the same happen with CO2? I assume the density of CO2 is different so the amount required would be more or less than O2, but it is still less dense than water so should rise?
Thanks
Edit:
After looking on google I can see that CO2 is 1.824 Kg/m3 whereas O2 is 1.331 Kg/m3. So you would therefore need 37% more CO2 to lift the same mass using O2.
Is that correct?
Thanks
Likes Xilus
Answers and Replies
jbriggs444
2019 Award
9,317
4,018
Is that correct?
No, it is not correct.
What is the density of water and how does that figure in?
sophiecentaur
4,824
There is a similar question, comparing Hydrogen and Helium for lifting power of balloons.
Take a look at this link about balloons (and lifting underwater).
I think we just have to consider that the O2 has mass. and the CO2 has mass. and we have to add that in. when its in that giant balloon. we can consider it to be its own object with a certian mass and a certian size (and extremly low mass). so lets just use 1m^3 volume.
I think the force from the water is going to be 1000 times greater than the weight of the O2 or CO2.
so the type of gas (while under water) has a really small effect.
I didn't account for F=ma or drag forces.
Related Threads on Does CO2 float?
  • Last Post
  • Last Post
