- #71
PeterDonis
Mentor
- 45,641
- 22,663
timmdeeg said:This is hard to imagine. The only layman interpretation I am aware of sounds like this: r is timelike inside the horizon, as it has only one direction, like time flows only in one direction. But the weirdness seems "only" to be a matter of the choosen coordinates and can be transformed away, you mentioned the Kruskal coordinates already.
The terminology of calling a coordinate "timelike" or "spacelike" is unfortunate since it doesn't really convey what's going one, especially if what looks like the *same* coordinate (r in this case) is said to be timelike in one coordinate chart (the interior Schwarzschild chart) and spacelike in others (ingoing Eddington-Finkelstein and Painleve). Here's what I think is a better way of looking at it:
A "coordinate" like r is really a shorthand way of referring to two different things. One is a set of surfaces in the spacetime: each surface is labeled with a unique value of the coordinate, and every event in the spacetime lies on one and only one of the surfaces. For example, in Schwarzschild spacetime, there is a set of surfaces of constant r that satisfies the above properties.
The second thing a coordinate refers to is a directional derivative: for example, r corresponds to [itex]\partial / \partial r[/itex], the rate of change of something in the "r direction". The thing to remember about this is to avoid the "second fundamental confusion of calculus" (I learned this term from George Jones, one of the mentors here, who pointed me at a reference to it in one of Roger Penrose's books): partial derivatives can change depending on what other variables are being held constant. So a coordinate defined as a directional derivative will depend on what other coordinates it is combined with in a specific chart.
You can probably see what's coming next: when you change coordinate charts, the two things above do not necessarily change together. For example, in all three of the coordinate charts for Schwarzschild spacetime that I mentioned above, the first aspect of the "r" coordinate is the same: i.e., the "r" coordinate in all three charts refers to the *same* set of surfaces of constant r. What changes from chart to chart is the directional derivative. This seems to be the usual convention for coordinate nomenclature: a given coordinate name, such as "r", is applied to a given set of curves; then the changes in the directional derivative between charts are captured by calling the coordinate "timelike" or "spacelike" in different charts, according to the direction the derivative points in.
As a concrete example, here's how things work out for all of the charts I have mentioned for Schwarzschild spacetime:
(1) The Schwarzschild chart. (Technically, there are actually two of these, exterior and interior, because the coordinates are singular on the horizon.) Outside the horizon, the directional derivatives look like this: [itex]\partial / \partial t[/itex] timelike; [itex]\partial / \partial r[/itex] spacelike; [itex]\partial / \partial \theta[/itex] spacelike; [itex]\partial / \partial \phi[/itex] spacelike. So a surface of constant t is a spacelike 3-surface; but a surface of constant r has one timelike and two spacelike dimensions. (I won't talk about surfaces of constant theta, phi here; angular coordinates work a little differently. The usual way of talking about them is just to say that, since the spacetime is spherically symmetric, we can think of it as a set of coordinate pairs (t, r), where each unique pair labels a 2-sphere, which is a spacelike 2-surface covering all possible values of theta, phi. So what I said above can be condensed to: outside the horizon, lines of constant t are spacelike, and lines of constant r are timelike, where each "line" is really a series of 2-spheres. The only exception is r = 0, which is a single point, and is not technically part of the spacetime because the curvature is infinite there--but that's a whole other post .)
Inside the horizon, the r and t derivatives switch directions: [itex]\partial / \partial t[/itex] is spacelike and [itex]\partial / \partial r[/itex] is timelike. This is what the common statements that "r is timelike inside the horizon" or "t is spacelike inside the horizon" refer to. You can also see that, inside the horizon, lines of constant *r* are now spacelike, and lines of constant *t* are now timelike. So the labeling of coordinates as "timelike" or "spacelike" will look backwards if you are looking at the lines of constant coordinate value instead of the directional derivatives.
(2) Ingoing Eddington-Finkelstein & Painleve charts. (I lump these together because they are the same in the aspects we're discussing; also I specify "ingoing" because there are also "outgoing" versions of these charts. I won't go into the difference here.) Outside the horizon, these are the same as the Schwarzschild exterior chart; [itex]\partial / \partial T[/itex] is timelike and the other three coordinate derivatives are spacelike. So (leaving out theta, phi again as above) lines of constant T are spacelike and lines of constant r are timelike. Note that we are using a different label, T, for the "time" coordinate because it refers to a different set of lines (or surfaces if we include the angular coordinates) than the Schwarzschild "t" coordinate does.
*On* the horizon (these charts are nonsingular at the horizon, so this is meaningful here), [itex]\partial / \partial T[/itex] is *null* in both charts. ("Null" means it points in the same direction in spacetime as a light ray--an outgoing light ray, in this case.) However, the other three coordinate derivatives stay spacelike in this chart. So on the horizon, lines of constant T are still spacelike, but lines of constant r are null. In fact, that is one way of stating the *definition* of the horizon: it is a null line (of 2-spheres) of constant r.
Inside the horizon, [itex]\partial / \partial T[/itex] is spacelike; this means that lines of constant r are spacelike. This is why it's impossible to "hover" at a constant r inside the horizon: you would have to move on a spacelike line, i.e., faster than light. But [itex]\partial / \partial r[/itex] is *also* spacelike inside the horizon in this chart; in other words, *all four* coordinates are spacelike inside the horizon! This seems very weird, but that's how it is; what it is really telling you is that, to get a timelike vector at all inside the horizon, you have to combine [itex]\partial / \partial T[/itex] and [itex]\partial / \partial r[/itex] with opposite signs; for example, a future-directed timelike curve will have positive [itex]\partial / \partial T[/itex] and negative [itex]\partial / \partial r[/itex]. This is just another way of saying that everything inside the horizon is forced to fall into the singularity. In Painleve coordinates, for example, an observer freely falling into the black hole from rest "at infinity" is described by the vector [itex]\partial / \partial T - \sqrt{2M / r} \partial / \partial r[/itex], where M is the mass of the hole in units where G = c = 1.
(3) The Kruskal chart. Here what we normally think of as "r" and "t" (or "T" in the Eddington or Painleve charts) are not coordinates at all: they are functions of the coordinates that are used to label curves. The actual coordinates T, X in the Kruskal chart don't have a straightforward physical interpretation, but they do have a key property that makes the chart nice for seeing the global structure of the spacetime: their directional derivatives work just like the ones for the standard Minkowski coordinates of special relativity. In other words, [itex]\partial / \partial T[/itex] is timelike everywhere, and [itex]\partial / \partial X[/itex] is spacelike everywhere, and their relationship is such that null curves (light rays) are always 45 degree lines in the chart.
In this chart, lines of constant r are hyperbolas outside and inside the horizon; and the horizon itself, r = 2M, is a null line, i.e., a 45-degree line. Actually, it is a *pair* of 45 degree lines in the "maximally extended" Kruskal chart, which is mathematically well defined but is not physically realistic (again, that's a whole other post); these lines are the asymptotes of the hyperbolas for r > 2M and r < 2M. For r > 2M, the hyperbolas are more vertical than horizontal, and for r < 2M, they are more horizontal than vertical, so it's easy to see how the nature of the r coordinate changes.
Lines of constant Schwarzschild t in the Kruskal chart are straight lines radiating from the origin (T = 0, X = 0, which corresponds to the point where the two horizon lines for r = 2M, the asymptotes of the r hyperbolas, cross). The exterior lines radiate to the left and right, and the interior lines radiate up and down. So again, it's easy to see how the nature of the Schwarzschild t coordinate changes from exterior to interior: the lines of constant t are obviously spacelike in the exterior and timelike in the interior.
Unfortunately, I don't know a simple way to describe how the lines of constant Painleve time or Eddington-Finkelstein time T (technically they aren't quite the same set of lines, but they're close) look on the Kruskal chart. But they are spacelike lines in both the exterior and interior regions.
