entropy1
- 1,230
- 71
Does MWI just say that everyone agrees about what the pointer of the measurement apparatus shows?
No, MWI leaves that an unanswered question.entropy1 said:Does MWI just say that everyone agrees about what the pointer of the measurement apparatus shows?
Yes, in a given branch all observers agree what the pointer shows.entropy1 said:I mean, given a particular branch.
It does.A. Neumaier said:It doesn't even model multiple observers, as far as I know.
How? Where is it modeled?Demystifier said:It does.
Well, if you accept that MWI models one observer, then extension to many observers is trivial. For instance, if one observer called Alice is modeled asA. Neumaier said:How?
Yes. Where does the second set of kets labeled l come from? Alice and Bob look at the same quantum system and the same pointer, but may get different readings because of subjective uncertainty.Demystifier said:Well, if you accept that MWI models one observer, then extension to many observers is trivial. For instance, if one observer called Alice is modeled as
$$|\Psi\rangle=\sum_k c_k|k\rangle|{\rm Alice}_k\rangle$$
(with self-explaining notation), then two observers, Alice and Bob, can be modeled as
$$|\Psi\rangle=\sum_k c_k|k\rangle|{\rm Alice}_k\rangle|{\rm Bob}_k\rangle$$
or
$$|\Psi\rangle=\sum_{k,l} c_{kl}|k\rangle|l\rangle|{\rm Alice}_k\rangle|{\rm Bob}_l\rangle$$
Is there something which you find clear in the first equation but unclear in the second or third equation?
The second equation (without l) corresponds to the case in which Alice and Bob measure the same observable, while the third equation (with l) corresponds to the case in which they measure different observables. So for your purpose you can ignore the third equation. Hence the state in one branch isA. Neumaier said:Yes. Where does the second set of kets labeled l come from? Alice and Bob look at the same quantum system and the same pointer, but may get different readings because of subjective uncertainty.
But why does the state of the universe decompose in the way you claim? The general state in a tensor product of the state spaces of System, Alice and Bob is not what you write, butDemystifier said:The second equation (without l) corresponds to the case in which Alice and Bob measure the same observable, while the third equation (with l) corresponds to the case in which they measure different observables. So for your purpose you can ignore the third equation. Hence the state in one branch is
$$c_k|k\rangle|{\rm Alice}_k\rangle|{\rm Bob}_k\rangle$$
so there is no any uncertainty within one branch. Alice and Bob in the same branch get the same readings.
But we are not talking about the general state. We are talking a special state corresponding to a situation in which both Alice and Bob measure the same observable with eigenvalues ##|k\rangle##. It is convenient to model such measurements with a state I have written. It is possible to have a more general model based on your state above, but even such a general model can be thought of as a model of two observers in MWI.A. Neumaier said:But why does the state of the universe decompose in the way you claim? The general state in a tensor product of the state spaces of System, Alice and Bob is not what you write, but
$$\psi=\sum_{klm} c_{klm}|k\rangle|{\rm Alice}_l\rangle|{\rm Bob}_m\rangle!$$
But there you already assume what is to be derived, namely that Alice and Bob always agree on the value ##k## measured.Demystifier said:We are talking a special state corresponding to a situation in which both Alice and Bob measure the same observable with eigenvalues ##|k\rangle##. It is convenient to model such measurements with a state I have written.
To understand what I assume, consider first a single observer. You would argue that in general one can haveA. Neumaier said:But there you already assume what is to be derived, namely that Alice and Bob always agree on the value ##k## measured.
Ok, that's reasonable. But the argument is needed, the formula cannot simply be assumed!Demystifier said:To understand what I assume, consider first a single observer. You would argue that in general one can have
$$|\Psi\rangle=\sum_{k,l}c_{kl}|k\rangle|{\rm Alice}_l\rangle$$
That is true, but such a general state does not correspond to the case in which Alice performs a reliable measurement of the observable with eigenstates ##|k\rangle##. Instead, if Alice performs a reliable measurement of that observable, then ##c_{kl}=c_k\delta_{kl}##. Do you agree so far?
Now by analogy, with two observers in general we have
$$|\Psi\rangle=\sum_{k,l,m}c_{klm}|k\rangle|{\rm Alice}_l\rangle|{\rm Bob}_m\rangle$$
The requirement that Alice performs a reliable measurement means
$$c_{klm}=a_{km}\delta_{kl}$$
while the requirement that Bob performs a reliable measurement means
$$c_{klm}=b_{kl}\delta_{km}$$
So the only way to satisfy both requirements at once is that
$$c_{klm}=c_{k}\delta_{kl}\delta_{km}$$
In other words, what I assume is that both observers perform reliable measurements, while the fact that their results match is derived from that assumption.
Do you need some additional argument, or do you just say that the original statement needed argument which is now provided?A. Neumaier said:Ok, that's reasonable. But the argument is needed, the formula cannot simply be assumed!
I referred to the argument you provided. It is clear and robust under approximations, hence satisfactory.Demystifier said:Do you need some additional argument, or do you just say that the original statement needed argument which is now provided?
MWI stands for Many-Worlds Interpretation, which is a theory in quantum mechanics that suggests the existence of multiple parallel universes. It explains the behavior of particles and the measurement process in quantum mechanics. The concept of measurement apparatus pointer is important in MWI as it helps to understand how the measurement process affects the state of a quantum system.
MWI proposes the existence of multiple parallel universes, also known as the multiverse. This means that MWI does not agree on the existence of a single reality, but rather suggests that all possible outcomes of a measurement exist in different parallel universes.
The measurement problem in quantum mechanics refers to the issue of how a quantum system transitions from a superposition of states to a definite state when measured. MWI explains this by proposing that the measurement process causes the universe to split into multiple parallel universes, each containing a different outcome of the measurement. This allows for all possible outcomes to exist simultaneously.
MWI is a controversial theory and is not widely accepted in the scientific community. It is considered to be one of the many interpretations of quantum mechanics, and there is no consensus on which interpretation is the most accurate. However, MWI has gained popularity among some physicists and continues to be a topic of research and debate.
The implications of MWI on our understanding of reality are still being debated. Some argue that it challenges our traditional understanding of reality and the concept of causality, while others argue that it is simply a different way of interpreting quantum mechanics. It also raises questions about the nature of consciousness and the role of observers in the measurement process.
