Does parallel universe exists ?
  1. Jan 8, 2010 #1
  3. Jan 8, 2010 #2
  4. Jan 8, 2010 #3
    Re: Does parallel universe exists ??
    Although Everett's http://en.wikipedia.org/wiki/Many-worlds_interpretation" [Broken]is considered mainstream, it's not the only one out there. In fact, a poll taken during the Quantum Mechanics workshop in 1997 revealed the Copenhagen interpretation was more widely accepted, although leading physicists have said for the last 20 years it should not be considered primary, and there are other theories, including MWI and decoherence, which explain it better.
    Here's a http://en.wikipedia.org/wiki/Interpretation_of_quantum_mechanics#Comparison"of the most common interpretations.
  5. Jan 8, 2010 #4
    Chronos
    Detecting parallel universes is the issue. We have not, and probably never will. I rate that hypothesis roughly equivalent to the tooth fairy.
  6. Jan 19, 2010 #5
    how can you say that much surely that parallel universe are just like a tooth fairy ,it may be possible,because scientists confirmed that time travel is possible, but they are not getting the way ,how it can be done? that's the main problem.
  7. Jan 19, 2010 #6
    So what is exactly parallel universe?
    Here I claim that there are gazillion of them. Prove me wrong.
    Or, here I claim that there is none. Prove me wrong.
  8. Jan 19, 2010 #7
    once look at this link-
    http://leminuteur.free.fr/us/Universes.htm
  9. Jan 20, 2010 #8
    Hmmm, parallel universes, this is a very complex topic, but I will try and describe it as clearly as I can.
    At the moment, most scientists believe in 4 'levels' of different universes, or multiverses. Each level is a different scenario of how we think parallel Universes could arise and what they would be like. I'll just go through them one by one, but won't bother much with Level II and IV multiverses because they are nasty.
    Level I
    Note: In this, Universe applies to all the little universes (such as our own) put together.
    Level I multiverses are based around the idea of 'Inflation'. Inflation is what we believe stopped all the matter created by the Big Bang recollapsing into itself moments after its spontaneous creation due to it own titanic gravity. I won't explain inflation here, that would take ages, just think of it as the heat of the Universe making it expand very quickly. Anyway, what many scientists think, is that inflation blew apart all the little 'grains' of early Universe that were starting to condense into smaller areas of space such as our own. This left all the little 'bubbles' of space stranded far away from each other, seperated by billions of light years worth of void. I'll try to explain it in a diagram. We are area 'A' and there is another area 'B' which got seperated from us in the moments after the big bang.
    <-- area A, 13.7 billion light years radii -- > <- 50 billion light years gap - > <-- area B, 13.7 billion light years radii -- >
    As the diagram above shows, both areas A and B can only see things in a sphere, radius 13.7 billion light years around themselves (Yes, I know earth isn't the centre of our area of space (or universe), but because physics is broken, every point in our area of space/universe looks like the centre of it). But, due to inflation there is a gap 50 billion light years wide in between the two areas, which means neither area will encroach on the other, or be aware of the other's presence for another 50 billion years. Effectively, they can be thought of as different universes.
    Seeing as matter can pop out of nowhere in a vicious way, we can effectively think of the number of these small, seperate universes as being infinate. You might think this would lead to an infinate number of different universes, but, quantum mechanics tells us that there is only a finate number of ways of putting together all the atoms in our universe, an enormous number, yes, but not an infnate number. This means that somewhere, approximately 10^10^115 metres away, there is an exact copy of our Universe. We can then lead this on to say that anything you can think of the Universe being like, will exist. Which means that there could be a universe where life took an extra 1000 years to develop, but apart from that is exactly the same, so if you could travel there, you would essentially have gone 1000 years into the past.
    Of couse, finding out which universe you want to go to, and how to get there may be impossible, but nevertheless, the chances of such a scenario as described above being reality, are pretty high.
    Level II
    Level II multiverses arn't worth talking about much. Essentially, a level II multiverse scenario is if the Universe (There's only one main universe for this unlike Level I) has multiple 'buds' of smaller universes, formed from minature Big Bangs, leading off it via wormholes. If you found a way of travelling through wormholes you could go to them, but physicists expect that in bud universes, there is a good chance of universal constants being different. For example, gravity could not exist, or magnetism could be strong enough to tear us apart, so you wouldn't want to go to them.
    Level III
    Our current idea of what Level III multiverses are and how they form was first thought up by the American scientist Hugh Everett III, he invented the 'Many Worlds Interpretation' of quantum mechanics which essentialy states that whenever a decision is made, a two or more new realities form, each accomodating for each possible outcome. This would lead to an incredibly large number of parallel Universes, seeing as even the slightest movement of an electron could be considered a decision.
    The famous 'Schrodinger's Cat Box' thought experiment captures the essence of a Level III multiverse rather well. Whilst the box is closed, only 1 reality exists, the moment the box is opened it splits into 2 realities - one in which the cat is dead, the other in which the cat is alive. Of course, this is very simplified but it does explain the basics.
    Level IV
    Level IV Universes are aslo not worth talking about seeing as they are the least likely. Essentially the theory behind it is, that each mathematical function has a Universe which was created by it. In a way, Level IV and Level II multiverses are similiar seeing as universal constants would be different and probably kill you if you tried to go there.
    And that's all I'll write for now, I'm sorry if it sounded like a science lesson, but I hope you enjoyed it.
  10. Jan 20, 2010 #9
    (c) Max Tegmark
  11. Jan 20, 2010 #10
    Nop, this is not Tegmark.
  12. Jan 20, 2010 #11
    Tegmark just invented a theory of Level IV multi-verses, a theory which most scientists think of as nonsense.
  13. Jan 20, 2010 #12
    I would say, currently a minority of scientists have accepted MUH. Once you accepted MUH (and MWI) the next step (Level IV) is unevitable.
  14. Jan 20, 2010 #13
    Not if you leave 50 bly gaps, between Hubble volumes.
  15. Jan 20, 2010 #14
    10^10^115 is a lot bigger than 50bly.
  16. Jan 20, 2010 #15
    Yes it is. Anyway, I think that, that estimate relates to one HOMOGENOUS universe, which is spatially infinite or simply big enough. You can search for identical arrangement of matter for volume of any radius, smaller or bigger than Hubble radius.
  17. Jan 21, 2010 #16
    i really enjoyed it ,it's good one
    thanks
  18. Jan 25, 2010 #17
    Wikipedia's definition of time travel is this :
    Time travel is the concept of moving between different points in time in a manner analogous to moving between different points in space, either sending objects (or in some cases just information) backwards in time to a moment before the present, or sending objects forward from the present to the future without the need to experience the intervening period (at least not at the normal rate).
    Please elaborate on how such an impossible feat can be achieved. Is time travel actually confirmed as possible?
  19. Jan 26, 2010 #18
    Chronos
    So wikipedia has an opinion? I do not find that compelling or convincing.
  20. Jan 26, 2010 #19
    Chronos
    There is no compelling observational evidence of parallel universes. Until such evidence is produced, it is pure fantasy. Pardon my hard core skepticism.
  21. Jan 27, 2010 #20
    Parrallel universes exist? No! Im of the opinion they've hit a wall, run out of ideas and this is the best they can come up with, and cos it sounds intricate, complex and unfathomable...then it must be right!...
    We live in a physical universe, it is all explainable, its not complicated in the way a lot seem to imply and its all out ther for us to understand...why complicate soemthing so simply beautiful. Why dont they try and complete the knowledge we have on the one universe we do know exists before they start explaining the mechanics of something that doesnt exist.....
  22. Jan 27, 2010 #21
    let us wait for some more years till the scientists invent the way.
  23. Jan 27, 2010 #22
    Signals separated by space-like intervals are those which travel at >c.Tachyons have been hypothesized, but never observed, with imaginary mass
    E=imc^2/i*sqrt(1 -v^2/c^2 ) so the term in the sqrt is reversed.
    With a minowski diagram, you can find that v>c in a frame is infnite in some other frame, it experiences no time between transition in space
  24. Jan 28, 2010 #23
    Chronos
    vin, I presume you realize you have correctly described a photon traveling through minkowski space.
  25. Jan 29, 2010 #24
    If the fundamental concepts are different in your "bud universe" theory, and there were wormholes to reach them, wouldn't that introduce catastrophic instabilities into our own universe? You can't have the laws of physics hold in one part then the laws of physics not hold in another part.
    Also, the level 1 universe section you wrote seems to be off, since I don't believe you were clear enough in your explanation to not be ambiguous.
    -- DoYouKnow
  26. Jan 30, 2010 #25
    I might make a picture to explain Level 1 multiverses if you like. I thought my explanation was enough.
    About Level IIs, the only reason constants might be different, is because they are supposedly formed by mini big bangs on the quantum scale where everything gets mixed up. Personally, I think Level IIs are silly. Level Is are more probable.
