Planck Length: Upper Limit on Photon Frequency & Momentum
In summary: It's speculative because we don't know what the consequences of a universe with infinitely many frames of reference would be.
negativzero
120
TL;DR Summary
Assuming that a wavelength shorter than the Planck length is not allowed, does that mean that photons can only carry so much momentum and no more?
Is it known how much momentum a photon possesses if it's wavelength is at the Planck length, and what happens if it's momentum is somehow increased from that?
negativzero said:
Summary: Assuming that a wavelength shorter than the Planck length is not allowed...
Very bad assumption. Nature doesn't care about the Plank length any more than it cares about the foot or the meter.
Yes. The momentum is ##h/\lambda##, where ##\lambda## is the Plank length.
Nothing special, as far as we know. The Planck units are expected to be the scale on which quantum gravity effects become apparent. As far as I'm aware this is simply because there's no other natural scale for such effects to start kicking in. We don't know what quantum gravity will look like yet, but we have no reason to expect the Planck units to be some kind of hard cutoff on the notion of length or momentum or whatever.
negativzero said:
Summary: Assuming that a wavelength shorter than the Planck length is not allowed, does that mean that photons can only carry so much momentum and no more?
It'd be better to assume that physics at the energy scale involved are not well understood, than to assume that photons with that energy are "not allowed".
Certainly we can assign a number to the energy and momentum of a photon whose wavelength is the Planck length.
Thank you. I hope I'm not transgressing to ask if this means the constant is a mensuration issue not a physical constant or limit of any kind?
Yes. (That's "yes that's what it means" not "yes you're transgressing" - you aren't).
This question comes so often that we have an Insights article about it: https://www.physicsforums.com/insights/hand-wavy-discussion-planck-length/
Let us assume that Special Relativity is a correct theory of nature. Suppose that a static observer points a red laser beam at you. You start moving to the direction of the laser.
The Doppler effect makes you to measure the frequency of the light higher than the static observer. Furthermore, if you move at a relativistic speed, the static observer sees your clock run slower than his clock. That makes the frequency you measure even higher.
You may measure the frequency of normal visible light as so high that in your frame, the wavelength is less than the Planck length.
A photon of light always in some frame looks like having more than the Planck mass worth of energy. That does not mean that it collapses into a black hole. However, if an observer who is static in the fast frame collides with the photon, suddenly 1.2 * 10^28 eV of energy is freed, and a collapse into a black hole might happen.
"You may measure the frequency of normal visible light as so high that in your frame, the wavelength is less than the Planck length. "
Thank you for that. Hypothetical frames of reference. I can't think of any hypothetical frames of reference that would apply, rushing in toward the point-like observer. But I'm not good at interpreting what the math means to physical reality. For instance, the mere fact that someone can imagine a different set of rules that create a different universe doesn't mean to me that such a universe would necessarily exist. Yet some math is famously accurate at describing reality. However, taking what you suggest to heart, I'm trying to imagine a universe where every photon has the momentum of a super black hole relative to infinite frames of reference. I infer that you somehow dismiss your picture of a cosmology wherein every photon measured from infinite onrushing frames is black hole. Is it too speculative to ask why not? I look forward to any reply.
1. What is the Planck Length?
The Planck Length is the smallest possible length that can be measured in the universe. It is approximately 1.616 x 10^-35 meters.
2. Why is the Planck Length important?
The Planck Length is important because it is believed to be the scale at which quantum gravitational effects become significant. It is also the scale at which the fabric of spacetime is thought to be discrete rather than continuous.
3. What is the significance of the upper limit on photon frequency and momentum?
The upper limit on photon frequency and momentum, also known as the Planck Energy, is the maximum energy that a photon can possess. This limit is important because it helps us understand the fundamental limitations of our current understanding of physics.
4. How does the Planck Length relate to other fundamental constants?
The Planck Length is related to other fundamental constants, such as the speed of light and the gravitational constant, through the Planck units. These units are derived from the Planck Length and are used to describe fundamental physical quantities.
5. Can the Planck Length be measured?
Currently, the Planck Length is too small to be measured directly. However, it can be indirectly studied through experiments and theories involving quantum gravity and the fundamental constants. It is also possible that future technological advancements may allow for direct measurements of the Planck Length.
