Does the Sun have a "year"?
Main Question or Discussion Point
Since the Sun orbits the Solar Systems' Barycenter about once in every 12 Earth years, wouldn't it make sense to say the sun has a "year" - at least in a casual way? After all, although the sun has a lot more mass that the Earth, it orbits the Barycenter no less than the Earth does. We talk about the other planets' "years" (in relative terms or Earth Years), so why not the sun?
I can think of two reasons right off the bat. First, how would we define a frame of reference relative to which we can define "once around"? (Perhaps we could use the path of the Solar System in its orbit around the galaxy as a reference line?) Secondly, it would seem that, due to the very irregular orbit of the Sun around the Barycenter, the "years" would never be the same length. Might the Sun "speed up" when closer to the Barycenter and "slow down" when farther away (just as a comet speeds up as it gets closer to the Barycenter)? Even if it didn't, the closer to the Barycenter it is over a given length of time the less distance it would need to traverse for a given number of degrees orbit.
I think one good reason to talk about the Sun's "year" would be that it would make it obvious that the Sun is not the gravitational center of the Solar System, and that the Sun is no less an "orbiting body" than the smallest asteroid.
Any thoughts?
Answers and Replies
.Scott
2,544
916
The reason that the sun's "year" is 12 years is that Jupiter's year is 12 years. And Jupiter's mass is more than the mass of all the other planets combined.
Likes sophiecentaur, Spinnor, DaveC426913 and 1 other person
stefan r
248
many clumps of mass near the surface will rotate around the baricenter every day (25 earth days).
.Scott
2,544
916
Including most of the corona.
I don't understand. Clumps of mass near the surface of the sun? "every day (25 earth days)"
chasrob
46
The sun orbits around the Milky Way galaxy once every ~237 million years. That could be called the sun's "year" in a sense.
Likes krater and davenn
stefan r
248
The sun rotates every 25 days. The barycenter is often inside of the photosphere.
It was a poor choice of words. I did not intend to imply that the Sun is "clumpy".
I read somewhere that the equator of the sun rotates faster than the poles. Do they mean that in the sense that the equator travels faster merely because it has farther to go in each rotation (just like the Earth), or does the equator actually "go around" faster, so that a point on the equator will perform a rotation in less time than a point near one of the poles. If this second description is the case, how do determine the speed of the rotation of the sun? Is it an average? This would seem to create some interesting currents, eddies, etc. in the Sun.
davenn
2019 Award
9,252
7,564
That statement needs to be defined/clarified much better as the rotation isn't the same between the poles and the equator
due to it being a ball of "gas"
Thanks for the helpful responses!
Likes berkeman
chasrob
46
Also called a Galactic Year.
stefan r
248
It is usually the gas near the equator that moves around the barycenter. Here is a nice video (skip to 1:05). In 2169 the barycenter will be close to the center of the Sun.
Neither the pole nor the equator take 12 years to rotate.
Likes Spinnor
Related Threads on Does the Sun have a "year"?
  • Last Post
  • Last Post
  • Poll
  • Last Post
  • Last Post
18K
