Exploring the Domain and Range of Functions
  • Thread starter cahiersujet
  • Tags
    Function
In summary, there are many types of functions that have a domain consisting of all real numbers and a range from [0,1]. Some examples include identity functions, piecewise functions, and functions involving trigonometric functions. There are also more exotic options such as functions defined by probability or irrational numbers. Ultimately, the possibilities are endless and it all depends on what specific definitions and restrictions are given.
cahiersujet
What function has a domain consisting of all real numbers and a range from [0,1]?
what kind of functions is it?
for example, if its an identity function, you can say "y=x for all x from 0 to 1"
also, if its a piecewise function, you can say "sin(x) for all x from 0 to pi, and sin(-x) for all x from pi to 2pi"I`m just answering the question for fun, and sure to help u; but wait others for more reliable answers
There are many you can define.
f(x) = x - floor(x) is one.
g(x) = ceiling(x) - x is another.
(notice that f(x) + g(x) = 1, except perhaps in the case of x an integer, depending on the particular definitions of floor and ceiling you're using).
Other examples?
h(x) = |sin x|
i(x) = |cos x|
j(x) = (sin x)^2
k(x) = (cos x)^2
Not feeling like a periodic answer?
(l_n)(x) = exp(-x^2n), for any even integer n, defines a family of such functions.
(m_q,n)(x) = x^n / (q+x^n), for any even integer n and any positive real number q
Looking for something more exotic?
let n(x) be the function which equals 0.5 if x is rational, and 1.0 otherwise.
let o(x) be the function which gives the probability of two events both occurring if they are independent and have probabilities o(x/2) and o(2x).
(just for fun, could somebody find a closed-form solution for this last function, if there is one? does it make sense, or is it missing a necessary "base case"? one can tell that that o(0) = 1, but... can the rest be found uniquely?)
So, in response to the OP's question... pick your favorite.
Lol, nevermind about that last question.
It turns out the only such function is o(x) = 1...
1. What is the definition of domain and range?
The domain of a function is the set of all possible input values, or independent variables, for which the function is defined. The range is the set of all possible output values, or dependent variables, that the function can produce.
2. How do you determine the domain and range of a function?
To determine the domain of a function, you must look at the restrictions on the input values. These can include limitations on the types of numbers or values that can be used, or any values that would result in undefined outputs. The range of a function can be determined by looking at the possible output values that result from the given input values.
3. Can a function have an infinite domain or range?
Yes, a function can have an infinite domain or range. This means that there are no restrictions on the input or output values, and the function can produce an unlimited number of possible values.
4. How do you graph the domain and range of a function?
To graph the domain and range of a function, you can plot the input values on the x-axis and the corresponding output values on the y-axis. The domain will be the set of x-values that are included on the graph, and the range will be the set of y-values that are included on the graph.
5. Why is it important to understand the domain and range of a function?
Understanding the domain and range of a function is important because it helps to identify any limitations on the inputs or outputs of the function. This can help to determine the validity and usefulness of the function, and also allows for better interpretation and analysis of the data produced by the function.
