How does doping work in semiconductors?
In summary: The extra electron from the donor atom gets pulled into the acceptor atom, and the acceptor atom now has a negative charge.
Niles
1,866
Hi all
It can be shown that the product of the hole and electron concentration is constant at a given temperature in a semiconductor, as long as the Fermi level is in the ~middle of the gab.
When we dope semiconductors, do we use the above argument? I.e., does doping work because of this argument?
If my question is unclear, I can explain it in a new way.
It is puzzling because of your last statement in the OP. When you dope a semiconductor, the Fermi level (or more precisely, the chemical potential) is no longer in the middle of the band gap. So I'm not sure how using "the above argument" would explain doping, i.e I'm not sure what you're getting at.
Zz.
My book says (and I am quoting): "Because the product of the electron and hole concentration is a constant independent of impurity concentration at a given temperature, the introduction of a small proportion of a suitable impurity to increase n, say, must decrease p." Here n is the concentration of electrons, and p is the concentration of holes.
And the correct assumption in the OP is: The distance of the Fermi level (i.e. the chemical potential, since we are dealing with semiconductors) from the edge of both bands is large in comparision with T.
I am using Kittel (it's page 207).
What I don't understand is, when we have a donor atom in a semiconductor, then the extra electron gets thermally excited to the conduction band. But that still brings down a hole to the donor energy level, right?
I still don't see how that passage that you quoted implied that the chemical potential doesn't change with doping. The fact that you now have more charge carriers in the conduction band when you n-doped means that the statistical count of charge carriers that determines the chemical potential has changed.
Zz.
You make a good point.
When we have a donor atom in a semiconductor, then the extra electron gets thermally excited to the conduction band. Does that bring down a hole to the donor energy level?
This is not similar to an intrinsic semiconductor where an electron promoted to the conduction band leaves behind a hole. The "donor" by definition, "donates" electrons to the conduction band. It doesn't leave any holes in the donor level.
Zz.
Ahh, I see. Very helpful.
Disregard my OP, but substitute it with the following statement: "It can be shown that the product of the hole and electron concentration is constant at a given temperature in a semiconductor, independent of impurity concentration at a given temperature." This is shown it both Kittel and Ashcroft and Mermin (standard textbooks within this field).
Is it because of this fact (i.e. that np=constant, where n is electron concentration and p is hole concentration) that we have a n-type semiconductor, when it contains donor atoms? I mean, if 1 donor atom donates 1 electron to the conduction band, does this imply that there is 1 hole less in the valence band, and thus we have a n-type semiconductor?
how does the acceptor atom get negatively charged ? can u guys answer the question
We regard the acceptor atom (e.g. gallium in germanium) as being a germanium atom, but with a negative charge in the nucleus and a missing electron (hole) orbiting the nucleus.
What is doping of semiconductors?
Doping of semiconductors is the process of intentionally introducing impurities into a semiconductor material in order to alter its electrical and optical properties. This is done to improve the performance of the semiconductor in electronic devices.
What are the types of doping in semiconductors?
The two main types of doping in semiconductors are n-type and p-type. N-type doping involves introducing impurities with extra electrons, such as phosphorus or arsenic, into the semiconductor material. P-type doping involves introducing impurities with fewer electrons, such as boron or aluminum, into the semiconductor material.
How does doping affect the conductivity of semiconductors?
Doping can either increase or decrease the conductivity of semiconductors, depending on the type of doping and the concentration of impurities. N-type doping increases the number of free electrons and thus increases conductivity, while p-type doping decreases the number of free electrons and decreases conductivity.
What is the purpose of doping in semiconductors?
The purpose of doping in semiconductors is to create n-type and p-type regions within the material, which are essential for the functioning of electronic devices such as transistors. Doping also allows for the control and manipulation of the electrical and optical properties of semiconductors, making them more versatile and useful in various applications.
What are the implications of improper doping in semiconductors?
Improper doping in semiconductors can lead to undesirable effects, such as decreased device performance, unreliable operation, and even failure. It is crucial to carefully control the doping process to achieve the desired properties and avoid any negative consequences.
  • Atomic and Condensed Matter
