What causes a sonic boom when traveling at Mach 1+?
In summary, an insubstantial observer following behind a jetliner at the same speed would not hear the sonic boom. The sonic boom is created by the plane breaching the sound barrier and the observer hearing it from the nose of the plane.
QuantumCrash
135
Here's a problem that's been bugging me.
We know that we get sonic booms because of the Doppler effect since, for an example, the jetplane over takes the soundwaves that it emits some time ago because it is travels faster than the speed of sound.
The overlapping of new sound waves it produce will cause the sonic boom.
(Feel free to correct the physics, I'm new at this topic)
Let us suppose that we are an insubstantial observer following behind the jetplane at exactly the same speed. What would we actually hear when the plane breaches the sound barrier?
We shouldn't hear anything denoting the crossing of the sound barrier. The "sonic boom" travels outward form the leading edge of the object making it. This forms a cone of sound that we the observers would be inside of (->). Never coming into contact with the "edges" of the cone, we would never hear the sound.
I'm assuming you named us an "insubstantial observer" so that we are making our own sonic boom, right? So, if wew are close enough and listening hard enough, we'd be hearing the rattling of the jet's bits & pieces due to increased turbulence as it approached mach1. Then we'd hear that all stop when it passed throught the sound barrier and the ride smoothed out once again. But we wouldn't hear the boom.
Actually, I wrote "insubstantial observer" to avoid any complications such as being subjected to intense heat from afterburn or being affected by air resistance. What I meant was that we are, say 50m directly behind the jet traveling at the same speed.
I posted this since the normal sonic boom models that we see are assuming that we are stationary. But what would we hear if we were following the source of the boom?
Ah, I get you. Anyway, we would not hear the boom. Actually, this hypothetical situation would put us in exactly the same position as the pilot of the jet. The nose of the jet is what makes the sonic boom, and the pilot sitting several feet behind the nose doesn't hear it. Make the jet 50m long, and you could sit at the tail end and make direct observations. So I suppose your thought-experiment has been done in real-life by anyone who sat in the rear-most seats fo the Concord! (they heard no boom)
That sounds logical I suppose. However, I always assumed that the engine was the source of the sonic boom since it was the one making the the noise in the first place. :confused: Effectively, this would result in exactly the same effect, but it would differentiate my thought experiment and those seated in the concorde since they are sitting in front of the noise source.
What is the Doppler Effect at Mach 1+?
The Doppler Effect at Mach 1+ refers to the change in frequency of a sound wave when the source of the sound is moving at or above the speed of sound (Mach 1 or greater). This effect causes the pitch of the sound to appear higher when the source is moving towards the observer and lower when the source is moving away from the observer.
How is the Doppler Effect at Mach 1+ different from the traditional Doppler Effect?
The traditional Doppler Effect only applies to objects moving at speeds slower than the speed of sound. At these speeds, the frequency of the sound wave changes due to the motion of the source. However, at Mach 1 or greater, the Doppler Effect also takes into account the change in frequency caused by the motion of the observer relative to the source.
What are some real-life examples of the Doppler Effect at Mach 1+?
One example is the sound of a supersonic jet passing overhead. As the jet moves towards the observer, the sound waves are compressed and the pitch appears higher. As the jet moves away, the sound waves are stretched and the pitch appears lower. Another example is the sound of a meteor entering Earth's atmosphere, which can create a sonic boom as it moves faster than the speed of sound.
How does the speed of sound affect the Doppler Effect at Mach 1+?
The speed of sound is a critical factor in the Doppler Effect at Mach 1+. As an object moves faster than the speed of sound, the sound waves it produces cannot travel ahead of it, causing them to pile up and create a shock wave. This shock wave is responsible for the loud noise and sudden change in frequency that is heard when an object breaks the sound barrier.
What are some applications of the Doppler Effect at Mach 1+?
The Doppler Effect at Mach 1+ is used in various fields such as aviation, meteorology, and astronomy. In aviation, it is used to calculate the true airspeed of an aircraft. In meteorology, it helps in studying weather patterns and predicting storms. In astronomy, it is used to measure the speed and direction of objects in space, such as stars and galaxies.
  • Other Physics Topics
  • General Engineering
14K
  • Mechanical Engineering
  • Classical Physics
  • Astronomy and Astrophysics
