Homework Help: Doppler Effect Compensation
  1. Jul 28, 2014 #1
    Trying to find the formula to generate a sin wave that would compensate for the Doppler effect if played from a car moving 50 mph past a stationary observer 1 meter from the car's path.
    2. Relevant equations
    [itex]ƒ_{observed} = \frac{v}{v+v_{s}}ƒ_{source}[/itex]
    3. The attempt at a solution
    Tried to work this out using variables first. Say d is the distance from observer to car's path.
    First, we want to keep the observed frequency constant, so rewrite Doppler formula for source:
    [itex]ƒ_{source} = \frac{v+v_{s}}{v}ƒ_{observed}[/itex]
    Then, taking the component of the car's velocity towards the observer
    [itex]V_{o} = V_{s}cosθ[/itex]
    Where θ is the angle between the car's path, and the direct line of sight to the observer.
    But we want this in terms of d, time t and Vs, so we can rewrite θ thusly
    [itex]θ=tan^{-1}(\frac{d}{V_{s}t})[/itex]
    And then plugging back into Vo, we get
    [itex]V_{o}=\frac{V_{s}}{\sqrt{(\frac{d}{V_{s}t})^{2}+1}}[/itex]
    So plug this back into our Doppler equation.
    [itex]ƒ_{s}=\frac{v+\frac{V_{s}}{\sqrt{(\frac{d}{V_{s}t})^{2}+1}}}{v}ƒ_{o}[/itex]
    I've tried graphing this using ƒobserved=440 Hz and Vs=22 m/s, and the graph is symmetrical about t = 0, when it obviously should not be. I'm not sure where I'm going wrong.
  3. Jul 28, 2014 #2
    vela
    Staff Emeritus
    Education Advisor
    Check your expression for ##\theta## in terms of ##d##, ##V_s##, and ##t##. Are you sure that's what you want?
  4. Jul 28, 2014 #3
    Why wouldn't it be? Tan gives me opposite and adjacent components which are d and tVs. Are you saying it should be sin or cos?
  5. Jul 28, 2014 #4
    vela
    Staff Emeritus
    Education Advisor
    Consider the sign of your expression for ##V_o## as you pass ##t=0##.
  6. Jul 28, 2014 #5
    Am I approaching this the right way? I don't see what else theta can be written as.
    would writing it in terms of cosine make sense? then [itex]V_{o}=\frac{V_{s}^{2}t}{\sqrt{d^{2}+V_{s}^{2}t^{2}}}[/itex]
  7. Jul 28, 2014 #6
    vela
    Staff Emeritus
    Education Advisor
    Your approach is fine, but you have to be a bit careful. Try plotting ##V_o## vs ##t##. Is it what you expect?
  8. Jul 28, 2014 #7
    Yes! this new Vo works. Thanks!
Have something to add?
Draft saved Draft deleted
