Doppler effect shifts
  1. Dec 6, 2016 #1
    An audio transmitter and receiver are mounted side by side as shown in the figure. The transmitter emits sound of frequency v. A distant flat plate approaches the instrument at speed Vtarget and the receiver detects sound waves of frequency v' reflected from the target. The difference in frequency between the emitted and detected frequencies can be used as a motion detector.
    A) Show that v'/v=v+Vtarget / v-Vtarget
    B) In many cases V[/SUB]target[/SUB] <<v . For such cases show that V'/v=1+2(vtarget /v)
    FIGURE: http://imgur.com/bLXnm2L
    2. Relevant equations
    Doppler effect
    3. The attempt at a solution
    Ive already accomplished A by realizing there were two doppler shifts and that the frequency gets larger as it goes to the object, than even larger than that when it bounces back to the receiver. Part B is where i'm stuck because im not sure what i need to assume to create that formula.
  3. Dec 6, 2016 #2
    haruspex
    Do you know how to expand (1+x)a as a power series in x?
  4. Dec 6, 2016 #3
    No, i havent learned about power series yet, how does that relate to this?
  5. Dec 7, 2016 #4
    haruspex
    For this question, you need to know that, for small x, (1+x)a can be approximated as 1+ax+O(x2), where O(x2) means terms that grow smaller "like x2" as x gets smaller. I.e. you can just approximate here as 1+ax.
  6. Dec 7, 2016 #5
    is x just a term for frequency in this situation? Im not sure im following your variables.
  7. Dec 7, 2016 #6
    haruspex
    x is anything at all, as long as it is small compared with 1.
    Your initial post is very confusing because you seem to have written v for frequency and for velocity of sound in air. Maybe it's just a confusing font. Allow me to rewrite it more clearly:
    You are given Vtarget<<Vsound. So what quantity << 1?
  8. Dec 7, 2016 #7
    so your variable x would be less than 1, or in the re formatted variable, Vsound would be <<1
  9. Dec 7, 2016 #8
    haruspex
    Yes.
    No, Vtarget<<Vsound. From that, find something that must therefore be <<1.
  10. Dec 7, 2016 #9
    Perhaps the frequency would be less than 1. Would i be correct in assuming that?
  11. Dec 7, 2016 #10
    haruspex
    No.
  12. Dec 7, 2016 #11
    OH. The Vtarget has to be <<1
  13. Dec 7, 2016 #12
    haruspex
    No.
    Forget the actual questionfor a moment. If you have two quantities y and z, and you are told y<<z, what quantity can you construct from y and z which is therefore << 1? (You understand what << means, right?)
  14. Dec 7, 2016 #13
    << means significantly less than. So id have to make a third quantity that is z-y?
  15. Dec 7, 2016 #14
    haruspex
    Yes.
    No. E.g. y=1 and z=100 would satisfy y<<z, but z-y would be 99. And I should have said that you want the absolute magnitude to be <<1, so swapping z and y won't do it either.
    Think about ratios.
  16. Dec 7, 2016 #15
    So what if we made a quantity that was 1/y. that would guarentee y<<Z if we just want it to be <<1
  17. Dec 7, 2016 #16
    whoops, that wouldnt work either because if y was 1/3 than it would be 1/(1/3) which is >>1. ill keep thinking.
  18. Dec 7, 2016 #17
    nvm im confused again
Have something to add?
Draft saved Draft deleted
Similar Discussions: Doppler effect shifts
  1. Doppler shift (Replies: 1)
  2. Doppler shift (Replies: 2)
Loading...
