Dot/cross product proof
rock.freak667
6,223
31
Prove that p(q.rXs)-q(r.sXp)+r(s.pXq)-s(p.qXr)=0
Where p,q,r,s are vectors and X denotes the cross product.
So far all I have is this ( I can't get any further after)
q.rXs=r.sXq=s.qXr
r.sXp=p.sXr=s.rXp
s.pXq=q.sXp=p.qXs
p.qXr=r.pXq=q.rXp.
Answers and Replies
tiny-tim
25,838
256
Hi rock.freak667! :smile:
(please either use more brackets, or write the triple product as [q,r,s])
Use the only other relation you know for the cross-product …
a x (b x c) = b(a.c) - c(b.a) :wink:
rock.freak667
6,223
31
But I do not have anything like b(a.c)-c(b.a) to convert back to a x (b x c) or vice versa
tiny-tim
25,838
256
D'oh! :rolleyes: forget reality … this is maths … use your imagination!
Big hint: what is (p x q) x (r x s) ? :wink:
Dick
26,263
621
Try this. Call your expression F(p,q,r,s). Can you show F(p,q,r,s)=-F(q,p,r,s)=-F(p,q,s,r)=-F(p,r,q,s)? It's not very hard if you rearrange the triple products. I.e. interchanging any two arguments flips the sign of F. That means, for example, F(p,p,r,s)=0. If any argument is repeated F is zero. It's also clear F is linear in each of it's arguments. That means we can figure out what F is by evaluating it on all combinations of the basis elements i,j,k. But in three dimensions we only have three basis elements. So F must vanish on all combinations. So F is zero. tiny-tim's suggestion sort of looks along the right lines, but (ixj)x(ixk) isn't zero. So (pxq)x(rxs) can't be the same as what you are looking at. It's not 'antisymmetric' enough.
rock.freak667
6,223
31
:biggrin: thanks for this hint, finally got it out now!
Dick
26,263
621
rock.freak667
6,223
31
So what did you do?
Well if I did it correctly, I believe (s.pXq)-s(p.qXr) works out as (p x q) x (r x s).
And p(q.rXs)-q(r.sXp) works out as (r x s) x (p x q)
Dick
26,263
621
Yep, I think you did it correctly. I was trying to find a trick where I didn't have to do the general antisymmetric thing, and couldn't find one. You and tiny-tim did.
Suggested for: Dot/cross product proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
