Double delta potential - boundary conditions
In summary, a double delta potential is a potential energy function used in quantum mechanics to describe the behavior of a particle in a one-dimensional system. The boundary conditions for this potential require the wave function and its derivative to be continuous at the two delta function points. The shape of the potential can affect the difficulty of satisfying these conditions. The boundary conditions can be solved analytically using the Schrodinger equation, but numerical methods may be necessary in some cases. These conditions have important physical implications, determining the allowed energy levels and wave functions for the system. They also affect the probability of finding the particle at specific points in the potential well.
SoggyBottoms
59
A double delta potential is given by [itex]V(x) = c_+ \delta (x + \frac{L}{2}) + c_- \delta (x - \frac{L}{2})[/itex].
Use the discontinuity relation to find the boundary conditions in [itex]x = \pm \frac{L}{2} [/itex].
The general solutions are:
[itex]
\psi(x) =
\begin{cases}
Ae^{ikx} + Be^{-ikx} & x < -\frac{L}{2} \\
Ce^{ikx} + De^{-ikx} & -\frac{L}{2} < x < \frac{L}{2} \\
Ae^{-kx} & x > \frac{L}{2}\end{cases}
[/itex]
So using the discontinuity relation, we get in [itex]\frac{L}{2}[/itex]:
[itex]ikAe^{ik\frac{L}{2}} - ik Be^{-ik\frac{L}{2}} - ikCe^{ik\frac{L}{2}} + ikDe^{-ik\frac{L}{2}} = \Delta \frac{d\psi}{dx} = \frac{2mc_+}{\hbar^2}\psi(\frac{L}{2})[/itex].
And that would be the first boundary condition...is any of this correct?
Yes, your approach is correct. Using the discontinuity relation, we can equate the difference in the derivative of the wave function at the boundary point with the potential function at that point. This gives us the boundary condition for the wave function at that point. In this case, we have two boundary points at x = ±L/2, so we will have two boundary conditions.
At x = -L/2:
ikAe^{ik(-L/2)} - ik Be^{-ik(-L/2)} = \Delta \frac{d\psi}{dx} = \frac{2mc_-}{\hbar^2}\psi(-\frac{L}{2})
At x = L/2:
ikCe^{ik(L/2)} - ikDe^{-ik(L/2)} = \Delta \frac{d\psi}{dx} = \frac{2mc_+}{\hbar^2}\psi(\frac{L}{2})
These boundary conditions will help us determine the values of the coefficients A, B, C, and D in the general solutions. So, in short, your approach and equations are correct. Keep up the good work!
FAQ: Double delta potential - boundary conditions
1. What is a double delta potential?
A double delta potential is a type of potential energy function used in quantum mechanics to describe the behavior of a particle in a one-dimensional system. It consists of two delta functions placed at different points along the x-axis, creating a potential well with a double peak.
2. What are the boundary conditions for a double delta potential?
The boundary conditions for a double delta potential are that the wave function and its derivative must be continuous at the two delta function points. This means that the wave function must have the same value and slope on both sides of the potential well.
3. How does the shape of the potential affect the boundary conditions?
The shape of the potential, specifically the distance between the two delta functions, can affect the boundary conditions. If the potential is very narrow, the boundary conditions may be more difficult to satisfy, as the wave function must be continuous and differentiable at a smaller space. On the other hand, if the potential is wider, the boundary conditions may be easier to satisfy.
4. Can the boundary conditions for a double delta potential be solved analytically?
Yes, the boundary conditions for a double delta potential can be solved analytically using the Schrodinger equation. This equation describes the behavior of a particle in a potential and allows us to determine the wave function and its derivatives at the two delta function points. However, in some cases, the boundary conditions may be more easily solved using numerical methods.
5. What are the physical implications of the boundary conditions for a double delta potential?
The boundary conditions for a double delta potential have important physical implications. They determine the allowed energy levels and wave functions for a particle in the potential well. If the boundary conditions are not satisfied, the energy levels and wave functions may not be physically meaningful. Additionally, the boundary conditions affect the probability of finding the particle at specific points in the potential well, providing insight into the behavior of the system.
