Double Root and Quotients in Differentiation of Polynomial Functions
In summary, the problem involves finding u and v such that 1 is a double root of p(x)= vx^{n+1}+ ux^n+1. This is equivalent to finding the stationary point where the graph of p(x) touches the x-axis at x=1. This leads to two equations, u+v+1=0 and (n+1)v+nu=0, which can be solved for u and v. When n=4, the quotient of p(x) divided by (x-1)^2 is 4x^3+3x^2+2x+1.
mtayab1994
584
[tex]p(x)=vx^{n+1}+ux^{n}+1[/tex]
1) Find u and v so that 1 is a double root for p.
2) Conclude the quotient of p(x) over (x+1)^2.
3) For n=4 find u and v and find the quotient of p(x) over (x-1)^2.
Can someone just tell me how to start this please. I really have no idea on how to start this off. Thanks in advance.
Edit: Sorry something else came to my mind.
1) If 1 is double root, then the graph of p(x) just touches the x-axis but does not cross it at x=1. This means that it must be a stationary point.
Yes, that's correct. At x= 1, p(1)= u+ v+ 1. In order that 1 be zero of p, we must have u+ v+ 1= 0. The derivative of p is p'(x)= (n+1)vx^n+ nux^{n-1}. In order that 1 be a double zero of p we must have p'(1)= (n+1)v+ nu= 0. That gives you two equations to solve for u and v.
After solving the system of equations that contained u+v+1=0 and (n+1)v+nu=0 I found that:
1)v=n and u=-n-1
2) The quotient of p when divided by (x-1)^2 will be [tex]nx^{n-1}+(n-1)x^{n-2}+(n-2)x^{n-3}+...+1[/tex]
3)When we take n to be 4 the quotient comes out to be 4x^3+3x^2+2x+1.
Is everything correct??
1. What is a double root in differentiation?
A double root in differentiation refers to a point where a function has a repeated root or a root with a multiplicity of two. This means that the function's derivative is equal to zero at that point and the graph of the function touches the x-axis without crossing it.
2. How is a double root different from a single root in differentiation?
A single root in differentiation refers to a point where a function's derivative is equal to zero and the graph of the function crosses the x-axis. On the other hand, a double root has a multiplicity of two, meaning that the function's derivative is also equal to zero at that point, but the graph only touches the x-axis without crossing it.
3. Can a function have more than one double root?
Yes, a function can have multiple double roots, or even more complex roots such as triple, quadruple, or higher order roots. This depends on the degree of the function and the number of times the function's derivative is equal to zero at a specific point.
4. How can we find the double root of a function using differentiation?
To find the double root of a function using differentiation, we need to first take the derivative of the function. Then, we set the derivative equal to zero and solve for the variable. The resulting value(s) will be the double root(s) of the original function.
5. What is the significance of a double root in differentiation?
A double root in differentiation can indicate the presence of a horizontal tangent line on the graph of a function, which can provide valuable information about the shape and behavior of the function. It can also help us determine the number of solutions to a given equation and the behavior of the function at that point.
