V711
- 61
Hi,
I posted my question on another forum:
http://physics.stackexchange.com/questions/143377/one-disk-ring-in-double-rotation-and-sum-of-energy
but it is "on hold" and nobody knows where is the error, so I try to post here if you are agree ? I can understand if you close the question because I asked on another forum. I ask here because I asked to a colleague teacher of physics this morning and he can't find the error. Maybe you can see where is my error.
http://imagizer.imageshack.us/v2/800x600q90/674/ZCCxsA.png
At time t=0
At time ##t=0##, I rotate a grey disk or ring with a rough outer surface at angular velocity ##w_1## around the blue axis (clockwise) and at ##w_2## around the green axis (counterclockwise) as shown in the figure. ##w_2## is relative to black arm.
Now, the kinetic energy of the system is:
##K_E = \frac{1}{2}md²w_1²+\frac{1}{2}mr²(w_1-w_2)²##
for a ring or
##K_E = \frac{1}{2}md²w_1²+\frac{1}{4}mr²(w_1-w_2)²##
for a disk, with ##d## the length of the arm, ##m## the mass of disk and ##r## radius of disk. Note again that ##w_2## is relative to black arm, the expression of kinetics is here.
I built N systems like that:
http://imagizer.imageshack.us/v2/800x600q90/910/RvX9fg.png
Noted blue axis are fixed to the ground. There is friction between disks. Like black arms are turning at the same rotationnal velocity, disks are always in contact. I count all energies including the energy of friction. For simplify the study I consider friction from disk/disk give the same force F even ##w_2## decreasing, it's possible to imagine a theoretical problem or in reality it's possible to imagine oil between disks and something remove oil more and more when ##w_2## decrease.
Friction can be obtain, for example, with two forces ##F1/F2##: disks must be side to side. These forces don't work. An example with 2 positions at 2 diffrent times:
http://imagizer.imageshack.us/v2/800x600q90/905/3niK6h.png
Forces that need energy are magenta forces (purple). But these forces need the same energy for 3 systems than for 10 or more. In the contrary, with 10 systems, heating is higher and energy of each disk increase too.
I guess no friction at green axis and at blue axis. At start, for prevent shock, I guess friction is added more and more like magenta forces. I guess friction is low, like that ##w_2## decrease slowly.
Works of forces
##F## is the value of green or magenta force
##w_{disks} = +N \frac{1}{2}mr²((w_1-w_{2i})²-(w_1-w_{2f})²)##
with ##w_{2f}<w_{2i}##
with ##w_{2f}##: ##w_2## at final and ##w_{2i}##: ##w_2## initial.
##W_{friction}=2(N-1)Frw_{2m}t## with ##w_{2m}## the mean of ##w_{2}##
##W_{F1}=2dF-2dF=0##
##W_{F2}=2dF-2dF=0##
##W{magentaforce}= -2Fdw_{2m}t##
##Sum=+N \frac{1}{2}mr²((w_1-w_{2i})²-(w_1-w_{2f})²)+2(N-2)Frw_{2m}t##
Sum of energy
At ##t=0##, the system (N disks) has the energy ##N(\frac{1}{2}md²w_1²+\frac{1}{4}mr²(w_1-w_2)²)##
At final, the system has the energy:
##N(\frac{1}{2}md²w_1²+\frac{1}{4}mr²(w_1-w_2)²)+N \frac{1}{2}mr²((w_1-w_{2i})²-(w_1-w_{2f})²)+2(N-2)Frw_{2m}t##
For resume
If I define ##2E_1## the energy that each disk give to heat. And I define ##E_2## the energy won by each disk because ##w_2## decrease. The energy needed by two last systems is ##2E_1##. With N systems, the sum of energy won by the system is ##(N-2)2E_1+NE_2##.
So :
a) My reasoning is false ?
b) I'm wrong somewhere in my calculations ?
c) I forgot a force or a torque, in particular on black arm ?
d) A movement can't be like I describe ?
e) The sum of energy is not constant in this case ? --------------------------------------------------------------------------------------------------------------
I added more cases for watch different positions of the system:http://imagizer.imageshack.us/v2/800x600q90/661/IjNCnC.png Following image shows blue axis fixed to the ground:
http://imagizer.imageshack.us/v2/800x600q90/540/S555kL.png
At time t=0
for a ring or
Works of forces
Sum of energy
For resume
So :
