Homework Help: Double-slit Interference
  1. Feb 19, 2012 #1
    A double-slit interference pattern is created by two narrow slits spaced 0.21mm apart. The distance between the first and the fifth minimum on a screen 60cm behind the slits is 6.2mm. What is the wavelength of the light used in this experiment?
    2. Relevant equations
    gamma = d/L * Delta y
    3. The attempt at a solution
    delta y = 6.2mm/5 = 1.24*10 ^-3m
    gamma = d/L delta y
    = (2.1*10^-4m)/0.6m * 1.24*10^-3
    = 434nm
    but this is incorrect. Where did I go wrong?
  3. Feb 19, 2012 #2
    vela
    Staff Emeritus
    Education Advisor
    If the 6.2 mm was the distance between the first and second minima, would you say the distance between the minima is Δy = 6.2 mm/2?
Loading...
