Downwind faster than the wind
  • Thread starter spork
  • Tags
    Wind
In summary, the person in the video built a wind powered vehicle that goes directly downwind - faster than the wind - steady state.
  • #71
ThinAirDesign said:
I'm quite surprised frankly that there are not more folks on a physics forum piping up and taking a position on a debate so fundamental to one of the most basic and long-standing physics principles.
No need frankly. They can wait for you and I to go and provide physical proof once again by taking the cart out on the road in a smooth tailwind, to show it behaves the same way.
  • #72
spork said:
In response to... "How can a vehicle move faster than the wind that is powering it?"
OmCheeto wrote:
"It cannot go faster than the wind when going directly downwind."
Then I built a cart that does exactly that, made a video, and posted it.
Yes you did, but as I pointed out, the parameters of the experiment changed.
For you next experiment, I think you should remove the RC steering control from the first vehicle, add it to your new mini-me "faster than wind" vehicle, and put it back on the treadmill. I bet it would go even faster.
Now OmCheeto incredulously writes:
hmmm... I thought I'd deleted my statement that the reason they called you charlatans was because you are charlatans.
For the record, you used the term before I did.
and my_wan tells me I haven't been insulted, I may not have the stomach for this, and this is "how science works".
There's a kind of twilight-zone sort of entertainment to this I suppose.
I agree. I keep unsubscribing to this thread, yet somehow I keep getting sucked back into this vortex.
I guess it's like forcing ones self to read some poorly written mystery novel, because no matter how bad it gets, you just have to know how it ends.
  • #73
OmCheeto said:
...but as I pointed out, the parameters of the experiment changed.
And as I pointed out - you're wrong. I defined the parameters of the experiment. I concieved of the solution. JB and I built the cart, and we demonstrated it doing EXACTLY what we claimed.
In point of fact I NEVER used to word "charlatan" except to complain about people calling me that.
Next time you feel you're about to get sucked back in you really should call a friend and have them talk you down.
I'll save you the trouble - I'm right. Sorry for the spoiler, but now you have no need to get "sucked back in" just to hurl insults at the ones who HAVE proved their point.
  • #74
Some members have a very bizarre definition of an "insult." Let me remind you that comments against someone's ideas, or someone's experiments are completely different to comments which are meant to solely put a member down, or insult them. The latter set are not permitted, as per the global guidelines.
The OP has given out way more than he has received, and in fact threw insults in his very first post here at PF. Thus, any remarks along the line of "self defence" are not going to wash.
Since there is clearly no hope of a civil discussion of this topic, this thread is done.
<h2>1. How is it possible for something to move downwind faster than the wind?</h2><p>The concept of moving downwind faster than the wind is based on the principles of relative motion and sailboat physics. When a sailboat is moving downwind, it is not only propelled by the wind, but also by its own momentum. This allows the boat to reach speeds that are faster than the wind itself.</p><h2>2. Is it true that a vehicle can move downwind faster than the wind?</h2><p>Yes, it is possible for a vehicle to move downwind faster than the wind. In fact, there have been several successful demonstrations of this concept, including the Blackbird land yacht and the Blackbird SR-7 wind-powered vehicle. These vehicles use a combination of wind power and their own momentum to achieve speeds faster than the wind.</p><h2>3. What is the maximum speed that can be achieved when moving downwind faster than the wind?</h2><p>The maximum speed that can be achieved when moving downwind faster than the wind is dependent on several factors such as the design of the vehicle, the wind speed, and the surface conditions. In most cases, speeds of 2-3 times faster than the wind can be achieved, but in ideal conditions, speeds up to 4-5 times faster than the wind have been recorded.</p><h2>4. Are there any limitations to moving downwind faster than the wind?</h2><p>While it is possible to move downwind faster than the wind, there are some limitations to this concept. The most significant limitation is the direction of the wind. In order to achieve speeds faster than the wind, the wind must be blowing in the same direction as the vehicle. Additionally, the vehicle must have a low enough drag coefficient to overcome the resistance of the air.</p><h2>5. Can this concept be applied to other modes of transportation, such as airplanes?</h2><p>While it is possible to move downwind faster than the wind with vehicles such as land yachts and wind-powered cars, it is not possible for airplanes to do so. This is because airplanes rely on lift generated by their wings to stay in the air, not wind power. However, the concept of relative motion is still applicable in aviation, as airplanes can fly faster than the speed of the wind they are flying in.</p>
10K
  • Other Physics Topics
  • Classical Physics
11K
40K
  • Classical Physics
12K
