Homework Help: Drag force and power
  1. Jan 3, 2016 #1
    A long cylindrical antenna of 9 mm (0.009 m) diameter is mounted vertically on a car moving at 100 km/h (27.778 m/s). Antenna is 920 mm long (0.92 m). Calculate the power required to move antena through the air with standard kinematic viscositiy ν = 1.46 ⋅ 10-5 m2/s.
    The given result is P = 104 W.
    2. Relevant equations
    F = 0.5 ⋅ ρ ⋅ v2 ⋅ CD ⋅ A
    where:
    F - drag force
    ρ = 1.2 kg/m3 - density of the air
    v = 27.778 m/s - speed
    CD - drag coefficient
    A - relevant area
    P = F ⋅ v
    where:
    P - reguired power
    3. The attempt at a solution
    First, I tried to find drag coefficient. To do that, I must find Reynolds number:
    Re = (v ⋅ d) / ν
    Re = (27.778 ⋅ 0.009) / (1.46 ⋅ 10-5)
    Re = 17123.4
    According to the diagram, for infinitely long cylinders, CD ≈1
    Also, relevant area is:
    A = diameter ⋅ height
    A = 0.009 ⋅ 0.92
    A = 8.28 ⋅ 10-3 m2
    Now, the drag force is:
    F = 0.5 ⋅ 1.2 ⋅ 27.7782 ⋅ 1 ⋅ 8.28 ⋅ 10-3
    F = 3.83 N
    Required power is equal to:
    P = F ⋅ v
    P = 4.37 ⋅ 27.778
    P = 106.4 W
    Is this the correct way to calculate this? Am I getting 2 watts more just because of "not so accurate" reading from the diagram above?
    Thanks.
  3. Jan 3, 2016 #2
    mfb
    2017 Award
    Staff: Mentor
    Why did the force change from 3.83 N to 4.37 N?
    Where does the value for the density of air come from?
    2% deviation is certainly fine if you take CD from the diagram.
  4. Jan 3, 2016 #3
    Thanks for reply.
    When I calculated the force for the first time, I read CD = 1.14 from the diagram and I got F = 4.37 N and P = 121.4 W, which was too much.
    Then I realised that the CD might be a little lower, so in second reading from the diagram, I read CD = 1. Then I got F = 3.83 N and P = 106 W.
    Since I typed that in a hurry, I missed to correct the value for the force in all equations. Sorry for that.
    In the book where I found this example under the text it is said that the air has standard characteristics, so the density is 1.2 kg/m3.
    So, this procedure is fine?
    Is there any other way to calculate CD in this case, because the "reading from the diagram" method is not so accurate?
    Thanks.
  5. Jan 4, 2016 #4
    mfb
    2017 Award
    Staff: Mentor
    The assumption that the antenna is in a free air flow is not so accurate either. Usually car antennas are attached to cars, and those influence the air flow. Taking a value of 1 should be fine, you won't get a 1% accuracy anyway.
Have something to add?
Draft saved Draft deleted
Loading...
