Drag Force Ratio
183
Calculate the ratio of the drag force on a jet flying at ##1200 km/h## at an atttude of ##15 km## to the drag force on a prop-driven transport flying at half that speed and altitude.The density of air is ##0.38(\frac {kg} {m^3})## at ##10 km## and ##0.67(\frac {kg} {m^3})## at ##5 km##.Assume that the air-planes have the same effective cross-sectonal area and drag coefficient C
##F_D=\frac 1 2CAρv^2##
Here C and A are the same so ## F_D## jet will be ##F_1## and ##F_D## plane will be ##F_2##
##F_1=ρ_1(v_1)^2## and ##F_2=ρ_2(v_2)^2##
The question ask ratio so we dont care about units ( I guess )
##ρ_1## which at 15 km is I found approximately ##0.235 (\frac {kg} {m^3})## ( from Inverse ratio )
##ρ_2## which at 7.5 km is I found ##0.525 (\frac {kg} {m^3})##
So ##\frac {F_1} {F_2}=4 \frac {0.235} {0.525}=1.79##
answer is 3.3
I dont know where I went wrong
Thank you
Answers and Replies
12,298
I don't see how you would get 3.3.
You have some rounding errors, apart from that I get the same result assuming the atmosphere has an exponential distribution in density. I guess you are supposed to make this assumption.
183
Yeah...I dont know too.This is all writes in the question.
Thanks
haruspex
Insights Author
2020 Award
37,150
7,273
You are given the densities at 10km and 5km, but asked about drag at 15km and 7.5km. Smells like a question that has been altered to different data, but not consistently.
183
I know...So I think I just let it go :)
12,298
It wouldn't fit to those values either, but of they might have altered even more values.
183
What an interesting question....
Related Threads on Drag Force Ratio
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
