\Seeking Value for Saturn V Rocket Drag Coefficient
In summary: I'm not sure.I think it's viable to use a constant value of Cd, as long as it's a reasonable estimate. For a more complicated model, you might need to adjust the Cd value accordingly.In summary, the drag coefficient doesn't always vary with altitude, but it can change with velocity and Reynolds number. RockSim may be able to provide a value for the drag coefficient for a Saturn V rocket.
jr1104
Hi, just found these forums, and they look very useful.
I'm a second year Aerospace Engineering student, and as part of a project I'm modelling the first stage of a Saturn V rocket. I'm using a linear and non-linear model, and have all the equations sorted out. The only problem is I can't really find a value that I can use for the drag coefficient. I'm aware that in real life this would change with velocity, as the Reynolds number would be changing, and the rocket would accelerate to supersonic speeds. But for the linear model, I need to just use an average figure. I'm wondering if anyone knows where I can find a value for this, or maybe just give me an estimate?
Thanks
Thanks, that looks useful. That thread doesn't seem to show any specific values for the drag coefficient though.
I found a program called RockSim that calculates Cd as a function of Mach number for model rockets up to M = 2. It isn't intended to analyze something as complex as a Saturn V, but it may give some useful results. There is a fully functional 30-day trial available.
Here is the link:
http://www.apogeerockets.com/rocksim.asp
EDIT: Apogee Components also offers a 1/70th Saturn V rocket kit. If I were you, I would ask them for a RockSim file for the Saturn V rocket.
http://www.apogeerockets.com/Saturn5.asp
I think the basic problem is that the drag varies with speed and altitude, so a constant Cd doesn't work... but I'm not an aero guy.
The drag coefficient never varies with altitude, as altitude only affects the density; however, the Cd will change as a function of Mach and Reynolds number, controls deflections [tex]\delta_c[/tex], and other variables I have omitted here for the sake of simplicity.
[tex]C_d = f(Re,Ma,\delta_c)[/tex]​
Typically, we account for this by having a series of lookup tables for aerodynamic data when coding the simulator.
Do those lookup tables include Cd's for a Saturn V?
If one were to code a simulator for a Saturn V, then it would. Each table is specific to an airplane. It's not a lookup table of different airplanes. I think this is what you are asking?
For instance, each lookup table has tabulated values of Cd, CL, Cy, Cl, Cm, Cn for various explanatory variables like: angles of attack, side slip, Reynolds and Mach number, controls deflection, throttle setting, etc.
By definition, Cd is a coefficient, and therefore a constant, for any given body. It's usefulness is limited to the common "drag equation," Fd=Cd*1/2*p*v^2*A.
Drag rise effects occur beyond this simple equation, both at very slow velocities, as well as approaching mach. At supersonic speeds, it's useless, and is replaced by equations for friction, vortex, lift-dependant wave, and volume wave.
More http://www.desktopaero.com/appliedaero/compress3d/ssdragest.html" .
Hey mugaliens, you have some misinformation concerning the drag equation so I am going to give you a slight course correction. The form of the drag coefficient is simply a consequence of dimensional analysis of the Buckinham-Pi theorem. It does not say, any where or at any time, that Cd is a constant in its derivation of Cd. I very carefully explained how Cd changes in my previous post. Please reread it again. The drag coefficient is defined for any flight regime, be it subsonic or hypersonic and has no relation to: "friction, vortex, lift-dependant wave, and volume wave."
Thanks for the information people, this is all useful stuff. Do you not think it's really viable then to use a constant value of Cd?
This is a rather basic model, and many assumptions are made, such as fixed control surfaces, thrust, and the rocket is traveling vertically. We haven't really covered much about the aerodynamics of supersonic flight yet, so it might be a bit beyond me to try and model that.
I saw it.
http://www.desktopaero.com/appliedaero/compress3d/supersonicaero.html" .
However, I will say I've seen Cd's use (I call it a misuse) as a function. Sure, one can take that approach. However, by definition, a coefficient is a constant, not a function. Second, if you're going to incorporate other factors into Cd, call it Fd, not Cd. Third, keeping Cd as a constant and incorporating other factors in the drag equations outside the simple drag equation helps to keep them separate, a critical factor in design.
When I earned my degree in the 80s, we were taught to keep Cd a constant and keep the other factors separate, and for some very good reasons.
Perhaps they're teaching people differently these days.
mugaliens said:
I saw it.
The only time your link comes into play is if one is trying to analytically calculate the drag coefficient. This does not mean the drag coefficient is constant, or that one necessarily has to care about: "friction, vortex, lift-dependant wave, and volume wave" because you can find the drag coefficient experimentally (and should to validate any calculations). Notice the plot in your link:
http://www.desktopaero.com/appliedaero/compress3d/images/image489.gif​
[/URL]
Clear as day, the drag varies with Mach number and is not constant!
You need to be careful here: the equation is fully 'useful' - at all times. I think you do not understand the application of this equation in calculating the drag vs. your link which is to calculate the drag coefficient. They are two very different things, and the implications are profound.
Then what you were taught, and have stated above, is wrong. It is not a misuse, it is standard practice to express the drag as a function of several explanatory variables and these functional dependencies are exactly what is known as the aircrafts stability derivatives, which is what I work with on a day-to-day basis as a flight dynamicist. These derivatives tell use about the stability, control authority, and performance of the aircraft and are used for finding the gains of autopilot design.
Instead of quoting some website ad nauseum, I strongly suggest you see:
[1] Aircraft System Identification by E.A. Morelli
[2] Dynamics of Flight by Etkin/Reid
[3] Flight Stability and Automatic Control by Nelson
for more rigorous background theory, and I will help to dispel further misconceptions. :smile:To jr1104: In light of the plot above, if I were in your position I would try to find some drag data on a missile that goes from subsonic to supersonic Mach numbers and use that. This will be "somewhat" - and I use this term very loosely - accurate. The problem is that at upper atmosphere the Saturn V is no longer flying through 'air', but rarefied gas. The underlying flow physics change dramatically and the Cd values you will find will be pretty useless. All sorts of fun stuff happens in rarefied gas: like the no slip condition on the boundary layer no longer being true!
Cheers Cyrus, I'll look into that. I used the Rocksim app linked above, and found a model of a Saturn V, and that uses a Cd value of about 0.95. Once I've coded the model, I'll try running it and see if I get sensible numbers out of it. I'm only modelling the rocket up to 68km, which is the limit of the first stage.
Are we really going to argue about the use of the term coefficient is? Puh-lease. I think there is enough professional usage since the beginning of forever to allow the usage. All drag coefficients depend on many factors, especially mach number and AOA.
Here's the plots for the V-2
The drag equation came into existence long before mach flight was ever possible, and at the time, its coefficient was considered a constant. Two schools of thought emerged. One was to include varying terms as additional functions in the equation, and the other was to cram it all into the drag coefficient.
The latter school of thought won out, but someone forgot to change it's name from a drag coefficient to a drag function.
In the 1980s, I worked as a Fortran programmer for NASA's computer complex in Slidell, LA. Although I worked on hull design (my degree was in AOE), my love was flying, and discussed many aerospace engineering concepts with the engineers there, including this issue of which you are apparently unaware.
While the latter school is by far the most common approach, it's not the only approach, and various researchers and designers have been known to separate the terms, for clear reasons relating to more precise enumeration of the various components of drag, most notably in transonic and supersonic research and design.
Sure...
Is there something wrong with Fred's graph? If so, please point it out.
I honestly don't know why you think the drag coefficient is a constant, it is not. At a freshman level, it varies with angel of attack. We both already know this, but I don't understand why you won't accept it. You seem to be caught up in nomenclature, all the drag coefficient does is represent something physically. It is a 'coefficient' and I say that in quotes, at each slice of time. At each instant we can think of it as a constant. But in general it is a multivariate surface! (It's an n-dimensional function)
I have never seen anyone state the drag coefficient is a constant - ever. You are going to need to have some references here. Even Anderson 4ed, chapter 1 p.84, has plots of drag coefficients as early back as the Wright brothers. There is even a chart of variation of normal and axial forces for various angles of attack by Lilienthal circ. 1897.
"In mathematics, a coefficient is a constant multiplicative factor of a specific object." (http://en.wikipedia.org/wiki/Coefficient" . They all say the same thing: A coefficient is a constant.
Again, in the early days of the drag equation, it was considered a constant (or approximately so) as well. Somewhere along the line, however, some aero engineers began cramming variables into it while never bothering to change it's name from "coefficient" to "function."
At a freshman level...
Gee, if you weren't taught at the freshman level that a coefficient is a constant, heaven help you! That doesn't speak well of your school.
I accept it's widespread use as something beyond a coefficient. I simply don't agree with it. Having done test and evaluation (research and design), I know for a fact we break out the variables into separate components, and for very good reasons: We want to know, precisely, the independant contributing factors of drag beyond simple incompressible and non-wave drag flow.
You seem to be caught up in nomenclature...
Actually, I'm caught up in reality, while you and Fred (and admitedly, a lot of other aero engineers) are caught in an inappropriate handling of the issue which began long ago.
(italics mine)
Then, by definition, it is not a "coefficient." :wink: And it is indeed a function.
The error of using the term "coefficient" instead of the more appropriate "function" (which you mentioned yourself, above) is indeed rather deep-seated...
No. For the n-th time, NO. An equation can be (a) constant coefficient or (b) non-constant coefficient form. We still use the word coefficient to describe either case. This is self evident in many, many mathematics books.
This again, is wrong. I have given you a source circ. 1897 that specifically tabulates them as a function of angle of attack. I can give you countless other books that do similarly. You must furnish some form of a valid reference for this claim.
Again, see above.
Yes, we break it into components. No, those components are not all constant. THAT is where you are wrong. Something being a constant, and something being broken into constituent pieces are not synonymous. You seem to think they are: why? No one claimed this. It is becoming clear that you are confusing these two points.
As my dynamics professor so eloquently said: when you're in a hole, don't keep digging it into a grave.
http://img9.imageshack.us/img9/5979/wrong1n.png
http://img521.imageshack.us/img521/9662/wrong1.png
Above are two separate books that clearly state you are wrong: mugaliens, please stop this line of argument. I see no merit in this argument, it does not gain any insights into the flow physics. Its just a grip about the meaning of coefficient.
Edit: If you are going to argue the definition of a coefficient, at the very least look to your math books first. This is from my PDE book:
http://img503.imageshack.us/img503/7523/byebyey.png
Can we now be satisfied?
mugaliens said:
I saw it.
No, you just didn't pay attention in aerodynamics class.
And WHEN was all this published?
Good stuff, to be sure, Cyrus. Just check your dates...
[PLAIN]http://img9.imageshack.us/img9/5979/wrong1n.png
[PLAIN]http://img521.imageshack.us/img521/9662/wrong1.png
[PLAIN]http://img503.imageshack.us/img503/7523/byebyey.png
Have you checked the dates, mugaliens? It's coming up on a year since this thread was last active.
The term "coefficient" as used in physics and engineering does not mean "constant". It just names some multiplicative factor, typically unitless, used in some larger equation. That is all the coefficient of drag is: a unitless factor used in some larger equation. If the coefficient of drag was constant, the drag equation would indicate that drag force is proportional to density, the square of velocity, and area. Change the density and flow can go from laminar to turbulent. The same goes for velocity and configuration. The switch from laminar to turbulent flow is not explicitly represented in the drag equation. It is instead embodied in the non-constant drag coefficient.
Because this thread is over a year old and because the OP's question was answered in full I am closing this thread.
1. What is a drag coefficient?
A drag coefficient is a dimensionless quantity that is used to quantify the drag or resistance of an object in a fluid environment, such as air or water. It is a measure of the object's ability to overcome the force of drag and maintain its motion through the fluid.
2. Why is it important to determine the drag coefficient for a rocket?
The drag coefficient is an important factor in the design and performance of a rocket. It directly affects the amount of thrust and fuel needed to overcome drag and propel the rocket to its desired destination. A lower drag coefficient means less energy is needed, resulting in better efficiency and cost savings.
3. How is the drag coefficient for a Saturn V rocket determined?
The drag coefficient for a Saturn V rocket can be determined through various methods such as wind tunnel testing, computer simulations, and flight data analysis. These methods involve measuring the aerodynamic forces acting on the rocket and comparing them to the rocket's size, shape, and velocity to calculate the drag coefficient.
4. What factors can affect the drag coefficient of a Saturn V rocket?
The drag coefficient of a Saturn V rocket can be influenced by several factors, including the rocket's shape, surface texture, and the properties of the fluid it is traveling through. Other factors such as temperature, pressure, and altitude can also affect the drag coefficient.
5. How can knowledge of the drag coefficient help improve future rocket designs?
By accurately determining the drag coefficient for a Saturn V rocket, scientists and engineers can use this information to improve the design of future rockets. By reducing the drag coefficient, rockets can become more efficient, require less fuel, and potentially reach higher speeds and altitudes. This knowledge can also be applied to other industries such as aerospace, automotive, and sports equipment design.
  • Aerospace Engineering
