Homework Help: Drag question
  1. Mar 24, 2014 #1
    At international cricket games, it is commonplace to display on the scoreboard a speed for each bowl. Because the ball is subject to a drag force due to air proportional to the square of its speed given by R = kmv^2, it slows as it travels 20 m toward the wicket according to the formula v = vie^(−kx). Suppose the ball leaves the bowler's hand at 151 km/h. Ignore its vertical acceleration, and determine the speed of the ball when it hits the wicket. (For a cricket ball, assume the mass is 0.16 kg, the radius is 3.5 cm, and the terminal velocity is 40 m/s. The density of air is 1.2 kg/m3.)
    2. Relevant equations
    Apart from the equations i have tried R=0.5DpAv^2
    but i don't know the drag coefficient!
    3. The attempt at a solution
    Honestly i don't know where to start, i have tried googling a similar question also.
    The problem is I cannot figure out R. If i knew drag coefficient i could work out k, then work out v over the distance
  3. Mar 24, 2014 #2
    AlephZero
    What is the drag force at the termimal velocity? You can work out "k" using that information.
  4. Mar 25, 2014 #3
    I worked drag force R out with R = -bV and using the above formal for R with a drag coefficient of .3 which i found online. Both gave a similar result. I got 133km/h
Have something to add?
Draft saved Draft deleted
