• Support PF! Buy your school textbooks, materials and every day products Here!
Drawing bode plot
NascentOxygen
Staff Emeritus
1,068
This for ILS's new problem? The break points (corner frequencies) will not be different when both factors are identically 1/(s+2). The break points must coincide.
The -40dB/dec slope is correct. :smile:
Femme_physics
Well, I followed the same logic as in the first exercise, didn't I?
I don't see why would they coincide if that same logic indicates differently.
NascentOxygen
Staff Emeritus
1,068
I haven't been able to follow ILS's "shortcut" method, but here's the amplitude plot with double poles at s=-2. So whatever method you use, to be valid it must produce this answer for 400/((s+2)(s+2)).
Note: horiz scale is Hz, not rad/sec, and Ѡ=2 rad/sec corresponds to f≃⅓ Hz.
gneill
Mentor
20,708
2,708
I think you'll find that the factored version of the transfer function spells out the poles conveniently in terms of the natural angular frequency (rad/sec).
It's as easy as that.
For single poles the slope increases by 20 db/decade, for double poles like ##(s + 2)^2##, the slope increases by 40 db/decade (that's still 20 db/decade per pole).
  • #31
Femme_physics
Then this logic does not match Nascent's graph who posted right before you. The break point seems to be at 0.1
Increase or decrease - that depends whether this expression is in the nominator or denominator
  • #32
gneill
Mentor
20,708
2,708
Right. His graph has frequency f in Hz along the x-axis. Natural frequency ω is in rad/sec, where ##ω = 2\pi f##.
Heh. Yes, by "increase" I meant steeper descent for each pole. Zeros in the numerator have the opposite effect, tilting the slope upwards by 20 db/decade for each zero.
  • #33
NascentOxygen
Staff Emeritus
1,068
That's because gneill helpfully threw in a new transfer function, for clarity.
Certainly.
  • #34
gneill
Mentor
20,708
2,708
That's because gneill helpfully invented another transfer function, for clarity.
Ah yes, er, that too :smile:
Actually I went back to the original transfer function for the thread, since I though it might be helpful to compare with the related plots.
  • #35
NascentOxygen
Staff Emeritus
1,068
The original TF had poles at -1 and -4. Though easy to get confused here, I know. :wink:
  • #36
gneill
Mentor
20,708
2,708
Aurrgh! So much for short term memory. Heck, it was only three pages ago, too!
  • #37
NascentOxygen
Staff Emeritus
1,068
  • #38
I like Serena
6,575
176
The way I described it, is how I learned it some time ago.
However, after gneill's and NascO's comments, I've looked it up on wiki, and I found this section on how to draw Bode plots by hand:
http://en.wikipedia.org/wiki/Bode_plot#Rules_for_handmade_Bode_plot
This is basically what they already said.
In the end I believe it is somewhat arbitrary, since the real transfer function plot does not consist of straight lines.
But I certainly concur that we should follow the standard methods.
Here's the graph I've made with the "actual" transfer function for ##G(s)={400 \over (s+1)(s+4)}##, my version, and NascO/gneill's version.
As you can see, it doesn't really matter (my version is actually closer), but I do propose to follow NascO/gneill's suggestions.
  • #39
NascentOxygen
Staff Emeritus
1,068
Well, now that ILS has cleared that up.... :wink:
there is no stopping yet, because as I pointed out earlier, we are only halfway there!
http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon2.gif [Broken] Don't forget that the Bode Plot requires a plot of angle vs. frequency as well as dB vs. frequency.
BTW, I think we have left FemmePhysics some miles back along the way. Should we turn back to look for her?
  • #40
gneill
Mentor
20,708
2,708
I'm sure that FP will track us down in due course. Probably just waiting for the dust to settle :smile:
  • #41
Femme_physics
I'm here! Except, I already had the Control Systems semester test yesterday. The sad part is that everything BUT the Bode Plot I'm sure I got right ;) But at least I didn't have to DRAW a graph, the graphs were given to me, I just had to find the function that describes it. So far I'm able to keep a 90+ average (out of a 100) with the help of physicsforums, or most specific you guys.
I had some solved examples to work with...hopefully I got it right. I might approach this thread before the final test of my degree (May-July), provided you'll still be around :)
I really appreciate your help, especially ILS that always goes above and beyond (amazing). If I didn't get the bode plots right I'll come here to whine, rest be assured!
Now I have machine parts test to take in 5 days so I better get in shape. :-) I appreciate your help, guys.
Related Threads for: Drawing bode plot
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
  • Last Post
