Drinking in Zero Gravity: Challenges and Solutions
  • Thread starter wakejosh
  • Tags
    Space
In summary, an astronaut in zero gravity would have to use air pressure to drink from a two liter, non-carbonated soft drink bottle through a straw, and would also have to continually "fish" for drops of liquid in the bottle.
wakejosh
102
an astronaut inside the shuttle is trying to drink from his smuggled two liter, non-carbonated soft drink bottle through a straw. what does the astronaut have to do to get a drink?
this seems kindof a trick question, because I don't see how gravity has anything to do with sucking through a straw, inside the straw becomes a vacuum anyway right?. Wouldnt it be no different than here on earth?
In zero gravity, liquid water will form large drops. As long as there is air pressure surrounding the drop, the straw can be inserted into a drop and the water can be sucked through the straw. If there were no air pressure on the drop, that would be impossible.
Check out this video of "eating" tea in zero g.
http://science.nasa.gov/ppod/y2003/07apr_hightea.htm
I would think that the astronaut would have to do something special where the straw goes through the neck of the bottle. At least if s/he doesn't want to make a mess!
It seems to me, the problems have to do with:
- what would push down on the surface of the liquid inside the bottle. Air pressure would, but gravity wouldn't.
- lack of gravity would also mean you couldn't simply place the straw at the bottom of the bottle. You'd have to continually "fish" to get the straw inside a floating drop of soda.
1. How do astronauts drink in space?
Astronauts use special containers that are designed for drinking in zero gravity. These containers have a valve and a straw that allow the liquid to be pulled up into the straw by the force of capillary action.
2. Can astronauts drink alcohol in space?
No, astronauts are not allowed to drink alcohol in space. Consuming alcohol in space can be dangerous due to the effects of zero gravity on the body and the limited medical resources available in the event of an emergency.
3. How does drinking in space affect the body?
Drinking in space can affect the body in several ways. The lack of gravity can cause fluids to shift from the lower body to the upper body, resulting in a puffy face and skinny legs. It can also cause difficulty in swallowing and can increase the risk of choking.
4. How do astronauts stay hydrated in space?
Astronauts have to drink a lot of water in space to stay hydrated. They are provided with special water dispensers that use a straw and a valve to pull the water into the mouth. They also have to monitor their fluid intake carefully to avoid dehydration.
5. Can astronauts drink from open containers in space?
No, astronauts cannot drink from open containers in space. Liquids in an open container would float around and could cause damage to equipment or even be inhaled by the astronauts. All drinks must be consumed from sealed containers with a straw or valve.
9K
9K
  • Beyond the Standard Models
