• Support PF! Buy your school textbooks, materials and every day products Here!
Driven RLC Circuits
  • Thread starter Ataman
Given a series RLC Circuit driven by a generator, Kirchhoff's Loop Rule gives:
[tex]V_{peak} cos \omega t - L\frac{di}{dt} - IR - \frac{Q}{C} = 0[/tex]
- OR -
[tex]V_{peak} cos \omega t = L\frac{d^{2}Q}{dt^{2}} + \frac{dQ}{dt}R + \frac{Q}{C}[/tex]
I have never done second order differential equations, so right now I am stuck if I want to solve for Q(t) or I(t).
-Ataman
Answers and Replies
193
I've just started studying differential equations, but this seems like a case where you could use the method of homogeneous and particular solutions, where you first find any solution that satisfies the differential equation (the particular solution), then find the homogeneous solution by setting the left side equal to zero and finding some general form (like Ae^st) that also satisfies the equation, and then summing the two. Unfortunately I'm not good enough to actually implement the solution for your problem, so hopefully there is someone else here that could expand on that or show a better way.
Related Threads for: Driven RLC Circuits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
