Dropping steel ball into water
In summary, the steel ball loses energy and the temperature of the water rises by 0.8 degrees Celsius.
navm1
44
If a steel ball of mass 100g and 100°c is dropped into 1litre of water at 20°c, what is the temperature rise? What would happen if it were dropped into a mixture of ice and water at 0°c?
Q=mcΔT
Q=mlm where ml is latent heat of melting
Q lost = Q gained
Qsteel = (0.1) (420) (-80) = -3360J
the steel ball loses 3360J so the water must have gained 3360J
Qwater = 3360 = (1)(4200)ΔT
ΔT = 3360/4200=0.8°C
so the waters temperature has increased by 0.8 degrees.
For the second part it didnt specify how much ice so i just chose to have 1 litre of water with 150g of ice at 0°c.
Qsteel = (0.1)(420)(-100) = -4200J
so the steel ball has lost 4200J of heat and the water ice mixture will gain 4200J of heat
Qwater = Qice = mlm
mice= Qwater/lm = 4200/3.35x105 = 0.0125kg
So only 12.5g of ice would be melted and the temperature wouldn't rise at all as the energy has gone into melting the ice and there is still a significant amount left.Am I on the right track here? Thanks
The first part was not done correctly. The steel ball will not cool all the way down to 20 C. Both the steel ball and the water will end up at the same temperature.
Chet
i thought i had the right idea but the numbers came out unusual
(0.1)(420)(x-100) = (1)(4200)(x-20)
42(x-100) = 4200(x-20)
42x-4200 = 4200x -8400
then from here i got
(42x-4200x)-4200= -8400
-4158-4200= -8400
-4158x = 4200 - 8400
in the end i ended up with 100/99 which can't be right.
if i calculate it with
(0.1)(420)(x-100) = (1)(4200)(20-x)
42x-4200 = 84000-4200x
42x+4200x = 84000+4200
4242x=88200
88200/4242 = 20.79
instead, i get 20.79°c which makes more sense but i thought delta T was always final minus initial
edit: this also means that the steel ball loses 3326.4J instead
The following equation is incorrect: (0.1)(420)(x-100) = (1)(4200)(x-20)
It should read: (0.1)(420)(100-x) = (1)(4200)(x-20)
The heat lost by the ball is gained by the water. Also, if you cancel before you multiply, the algebra is much simpler:
(100-x)=100 (x-20)
Chet
so now i have
4200-42x = 4200x - 84000
4200 + 84000 = 4242x
88200/4242 = 20.79
(0.1)(420)(79.2) = 3326.4J
so same answer before but a positive 3326.4J as the answer making the temperature rise 0.8c . i was expecting it to be negative because the ball is losing energy.
thanks
navm1 said:
so now i have
88200/4242 = 20.79
so same answer before but a positive 3326.4J as the answer. i was expecting it to be negative because the ball is losing energy.
thanks
The solution I get to your original equation is 19.2 C. You must have made a compensating mistake in the algebra somewhere.
Also, the 3326 J is the amount of heat lost by the ball.
I put the whole equation into wolfram alpha to double check and got the same answer too http://imgur.com/iatFmIJ
For the second question if I had 500g water and 500g ice would I use 0.5 for my mass of water or does the ice make it 1kg?
With all due respect to wolfram alpha, it can't be the same answer if you replace (x-100) with (100 - x).
Neither. After the steel ball is dropped in, a small amount of ice would melt to form liquid water, but the temperature of the ice water mixture would not change. All the heat from the steel ball would go into melting the small amount of ice.
chet
chet
You said to use
(0.1)(420)(100-x) = (1)(4200)(x-20), if I use x-100 I get 19.2. Apologies for missing the point
1. How does dropping a steel ball into water affect its velocity?
When a steel ball is dropped into water, its velocity will decrease due to the resistance of the water. As the ball moves through the water, it creates turbulence and experiences drag, causing it to slow down. The amount of velocity lost will depend on the size and weight of the ball, as well as the depth and density of the water.
2. Why does a steel ball sink in water?
A steel ball sinks in water because it is denser than water. The density of steel is approximately 7.8 grams per cubic centimeter, while the density of water is 1 gram per cubic centimeter. This means that the steel ball is heavier than the water it displaces, causing it to sink.
3. How does the temperature of the water affect the steel ball's descent?
The temperature of the water can affect the density of the water, which in turn can affect the steel ball's descent. Cold water is more dense than warm water, so a steel ball will sink faster in cold water compared to warm water. However, the difference in descent speed may be minimal and may not be easily noticeable.
4. Does the shape of the steel ball affect its descent in water?
Yes, the shape of the steel ball can affect its descent in water. A ball with a smooth, streamlined shape will experience less drag and will descend more quickly compared to a ball with a rough or irregular shape. This is because the smooth ball creates less turbulence as it moves through the water.
5. How does the depth of the water affect the steel ball's descent?
The depth of the water can affect the steel ball's descent in two ways. First, the deeper the water, the greater the pressure exerted on the ball, which can cause it to sink faster. Second, the depth of the water can also affect the amount of drag experienced by the ball. In shallow water, the ball will experience more resistance and will descend more slowly compared to in deeper water.
