Dual DC power supply
Hi,i really need help on how to design a dual channel DC power supply that fulfills the following specifications :
1) Operation - User selection between independent adjustment for positive and negative output voltage, and series tracking mode (slave channel tracks the master channel)
2) Output voltage amplitude : 0-20V± 5%
3) Current limit : 0 - 1.5A± 10%
4) Powered Directly from main supply
5) Indications of power on, constant voltage and constant current mode
I really hope you guys will be able to help me and provide me with a schematic to achieve the above specifications..thanks in advance =)
Answers and Replies
jim hardy
Dearly Missed
9,847
4,888
that schematic should produce from 1.2 to 27 volts.
check datasheet for your regulator.
http://www.ti.com/lit/ds/symlink/lm117.pdf
EDIT make that "that schematic should produce from 1.2 to about 19 volts.
what limits it to 19V is volts available from transformer.
15 X sqr(2) = 21 volts, less drop across bridge.
use a higher voltage transformer, something like this:
http://www.allelectronics.com/make-a-store/item/TX-398/POWER-TRANSFORMER-39.8V/22.5V-2.25A/1.html [Broken]
and you should do fine.
wow..thanks a lot..appreciate it =)
Related Threads on Dual DC power supply
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
