Dumb partial fractions question
  • Thread starter cabellos
dumb partial fractions question....
suppose i get x+1=A(x-2)+B(x-2)
how do you then find A and B?
Answers and Replies
Hootenanny
Staff Emeritus
Which values of x could you chose so that the equation simplified to leave you with a single unknown?
arildno
Dearly Missed
10,025
134
By demanding you've got an IDENTITY there, and remembering that the functions f(x)=1 and g(x)=x are linearly INDEPENDENT functions.
This will give you two equations for your two unknows A and B.
But say I use 2 as my x value, it removes both A and B in this equation....
arildno
Dearly Missed
10,025
134
Oops, I didn't see that closely!
You've made a mistake somewhere.
i haven't made a mistake i have to find the inverse laplace transform of s+1/(s^2 - 4s + 4) and im using partial fractions to do this.........but im stuck now......:cry:
OlderDan
3,021
The denominator is a perfect square. You need to use a different form for the sum of fractions. Have you seen this before?
Is that s+1/(s^2 - 4s + 4) or (s+1)/(s^2 - 4s + 4)??
I assume the second based on your original equation.
ok thanks - does this mean i find the inverse laplace transform of 1/(s-2)^2 and add this to the inverse LT of s/(s-2)^2 ??????????
I can do the first that would be te^2t wouldnt it?
Not sure about the second part???? :cry:
OlderDan
3,021
If you can use tables, go here
http://www.vibrationdata.com/Laplace.htm
2.10 confirms your first term, and 2.15 cannot be used for a perfect square denominator. Partial fractions will get rid of the s in the numerator for you, and you will get a 2.9 form and a 2.10 form. Yes??
i can see the first relationship with 2.10 but what do i need to do to s/(s-2)^2 ? use partial fractions? Thats what i tried at the start but how do i find A and B if s = A(s-2) + B(s-2) ?
OlderDan
3,021
You cannot use that form when the denominator is a perfect square. Use
(s + 1)/(s - 2)² = A/(s - 2) + B/(s - 2)²
how does that change anything........still can't solve A and B??
OlderDan
3,021
Sure you can.
s + 1 = A*(s - 2) + B
s + 1 = As - 2A + B
A = 1
1 = -2A + B
B = 1 + 2A = 3
Related Threads on Dumb partial fractions question
  • Last Post
  • Last Post
  • Last Post
S
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
