Dynamic problem
  • Thread starter hastings
hastings
80
an object with m=100kg is moving on a straight line. for t=0 its speed is v0=20 m/s. There's a force which is opposing to the movement F=C*v^2 ( C=1kg/m and v is the speed (v(t)=...) ). Find the time t1 in which the speed v=v0/2.
F=m*a (?)
v(t)=a*t+v0
v1=a*t1+v0 --> v0/2=a*t1+v0 --> t1=(-v0/2)*1/a
assuming a (accelation) constant
m*a = F = C*v1^2= C*(v0/2)^2
a= [C*(v0/2)^2]/m
Putting a in
t1= (-v0/2)/a should be getting the answer
Unfortunately the answer I get is not correct (should be 5second)
Answers and Replies
cepheid
Staff Emeritus
38
The acceleration is not constant because the force is not constant. Think about it. The drag force is proportional to the square of the velocity.This means that as the object slows down (due to the drag force), the drag force itself decreases. So not only does it decelerate, but it decelerates at an ever decreasing rate. You need a new way to approach this problem. Using the dynamical equations derived for the special case of motion under a constant force doesn't cut it here.
hastings
80
then how to solve it?
arunbg
594
Big hint: Think Newton's Second Law and think calculus....
hastings
80
F=m*a=C*v^2
so a=(C*v^2)/m
a=dv/dt ==> v=integral ( (C*v^2)/m )= C*v^2/m * t
so then
t= (v*m)/(C*v^2)=m/(C*v)
I then say
t0=0
t1 -t0=t1
t0=m/(C*v0)
t1= 2m/(C*v0)
t1= t1-t0= m/(C*v0)=5 seconds
arunbg
594
Umm..not quite.
v is actually dependent on t, and so you can't treat it as a constant.
You should write
[tex]\frac{dv}{dt}=Cv^2/m[/tex]
[tex]\frac{dv}{v^2}=Cdt/m[/tex]
And integrate on both sides.
And don't forget the constant of integration whose value can be determined with the given data.
hastings
80
[tex]\int{\frac{1}{v^2}}dv[/tex]? How to do it? I dunno
Maybe [tex]-\frac{1}{v}[/tex]?
Then what about [tex]\int \frac{C}{m}dt= \frac{C}{m} \cdot t+ c_0[/tex]?
arunbg
594
You are perfectly correct, why did the doubts arise?
Anyway can you proceed now?
hastings
80
So is it ....
[tex]-\frac{1}{v}+v_0=\frac{C}{m} \cdot t [/tex]
[tex] t=\frac{m}{C} \cdot ( -\frac{1}{v}+v_0)[/tex] ?
Then I substitute [tex]v=\frac{v_0}{2}[/tex] in the last expression and I should get the answer, right?
result should be 5 seconds.
Let's see...
Well...it's not right
arunbg
594
I notice that in the question, it is mentioned that the mass is decelarated. This means you should assign a negative value to acceleration.
Not quite, v_0 refers to velocity at time t=0.
Integrating, you should get
-1/v + K(constant of integration) = -Ct/m
Can you find K?
hastings
80
Thought it was K=v0; wouldn't know How can I get it ?
arunbg
594
At t=0, v=20. For LHS=RHS, K= ....
hastings
80
What's LHS=....? :eek:
Never heard
Is it K=20? but that's what i said previously: K=v0=20
arunbg
594
LHS - Left hand side RHS - Right hand side (for the equation -1/v + K(constant of integration) = -Ct/m) ) :smile:
What I'm saying is put t=0 and v=20 in this equation and find K.
cepheid
Staff Emeritus
38
LHS - left-hand side (of the equation), that's all
hastings
80
so k=1/20
[tex]-\frac{1}{v} +\frac{1}{20}=-\frac{C}{m} \cdot t[/tex]
Is it right?
Now I substitute t=t1 and v=v0/2 in the expression?
[tex]-\frac{1}{v} +\frac{1}{20}=-\frac{C}{m} \cdot t1[/tex]
[tex]t1=(-\frac{m}{C}) \cdot (-\frac{1}{v} +\frac{1}{20}) =[/tex]
[tex]=(-\frac{m}{C}) \cdot (-\frac{2}{v_0}+\frac{1}{20})=[/tex]
[tex]=(-\frac{m}{C}) \cdot (\frac{-2 \cdot 20 + v_0}{20 \cdot v_0})=[/tex]
[tex]=(-\frac{m}{C}) \cdot (\frac{-40+v_0}{20 \cdot v_0})=[/tex]
[tex]=(-100) \cdot (\frac{-40+20}{20 \cdot 20})=[/tex]
[tex]=(-100) \cdot (\frac{-20}{400})= 5 \mbox{ seconds }[/tex]
OK! GREAT! Thank you! :blushing: :rofl:
Suggested for: Dynamic problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
