Dynamics: 2 block problem
Assuming no friction is on the plane or the pulleys and the pulley and rope have negligible mass... Determine the acceleration of each block and the tension in each cord. Block A weighs 100kg, Block B weighs 300kg.
ΣF = ma
ma = 100kg
mb = 300kg
ΣFx = max = T1 = 100ax
ΣFy = may = W - T2 = 2943kg - T2 = 300ay
T1=2T2
I know that I have the relationships right, but I don't know exactly how to extract them...
Answers and Replies
What is the relationship between ax and ay? It is constrained motion, so you relate the two accelerations.
I think I solved it this way based off of what my professor drew on the board but I need some clarity because I'm not quite sure how this can be...
if we assume:
ax = 2ay
^My professor's hint
then we have 4 relations and 4 unknowns. So:
T1 = 2T2
100ax = 2[2943 - 300ay]
50ax = 2943 - 300ay
ax = 2ay
50*2ay = 2943 - 300ay
400ay = 2943
ay = 7.3m/s^2
ax = 14.8 m/s^2
**Edit**
This is an incorrect answer. The correct answer is 8.4m/s^2 for ax which means somewhere my answer is almost 2 times larger.
Related Threads on Dynamics: 2 block problem
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
