- #1
supersix2
- 26
- 0
For some reason I just don't get my dynamics homework. Here are the few problems I am having.
Problem 1:
A river is flowing north at 3 m/s (uniform current). If you want to travel in a straight line from point C to point D in a boat that moves at a constant speed of 10 m/s relative to the water, in what direction should you point the boat? How long does it take to make the crossing?
Point C is on the west bank of the river and the river is 500 m wide. Point D is 400 m north of point C on the east side of the river. Basicaly points C and D and the east side of the river make a right triangle with a base of 500 and height of 400 and the hypontenuse CD.
I found the angle of CD to be 38.66 degrees.
I set my coordinate system so that north is positive y or j direction and that east is positive x or i direction.
My first step was to find the the velocity of the the boat and to do that i used the following equation.
Velocity of the boat relative to river (10 m/s) = Vcos(38.66)i + Vsin(38.66)j - 3j
V = velocity of the boat
I found the magnitude by taking the square root of all of that and solving for V (i had to use the quadratic formula to get the roots for V). Therefore:
V= 11.62 m/s
Now I'm stuck. I have no idea where to go from here to find the direction. I substituted 11.62 back into my original velocity equation to get:
V wrt river = 9.07i + 4.26j
I'm thinking that that is only the componets of the velocity not the actual direction the boat is pointing maybe I'm wrong I don't know. Please help.
**Forgot to add the other problem I was stuck on
Problem 2:
A particle moves in a spiral path described by r = 1m and θ = 2z rad (where z is in meters) and moves along the z axis at a constant speed of |v | = 1000 m/s. What is the velocity of the particle in terms of cylindrical coordinates?
I have an equatoin that shows the velocity in cylindrical coordinates which is:
v = dr/dt êr + ω êθ + dz/dt êz
And there I am stuck. I think I can find ω by multiplying the the velocity by 2z because that would be ds/dt * dθ/ds. But after that how would i go about finding dr/dt and dz/dt? The ê are the unit vecots in the r, θ, and z directions respectively.
Problem 1:
V= 11.62 m/s
Problem 2:
