Dynamics problem
Warning! Posting template must be used for homework questions.
this is a part of a much bigger problem, I have a 600lb motorcycle going from point A to point B, which are 500 ft apart, i know the force exerted by the road on the motorcycle when the throttle is pressed is F(t)=300(1-.1t).
I need time in order velocity at B ,
I'm really lost on where to start on this, i was thinking f=ma could give me acceleration, but then i dont know what to do with that.
Answers and Replies
88
Are you trying to determine the velocity at point B?
If you know the acceleration then by definition you should be able to get the velocity.
so f=ma will give me a acceleration as a function of t, and yes i need velocity at B, but then won't i only have velocity as a function of t if by definition?.
RUber
1,687
344
Right, but if you have velocity, you can find position. Find how long it takes to get to point B, then use that t for your velocity.
SteamKing
Staff Emeritus
12,798
1,670
Gee, if only there were a way that acceleration could be used to get velocity, and that velocity could then be used to find distance. It would seem to be a good reason to study rectilinear motion in physics, or something. Maybe somebody wrote a textbook on how to do this stuff. IDK, that would probably take a lot of work to figure out.
so would i use Vi^2=Vf^2+2A(500) and substitute in V and A as their function of t equations? because then i get t= 10.05 does that seem right?
RUber
1,687
344
What units are you using for m, F, and distance? I hope F is in ft/lbs.
haruspex
Insights Author
2020 Award
37,000
7,217
No, that formula only works for constant acceleration. You need to use the general relationships between acceleration, velocity, and distance - namely, integral formulas.
Related Threads on Dynamics problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
D
  • Last Post
  • Last Post
  • Last Post
  • Last Post
