Homework Help: Dynamics question 2.
  1. Dec 22, 2008 #1
    At a certain point in the reentry of the space shuttle into the earth's atmosphere, the total acceleration of the shuttle may be represented by two components. One component is the gravitational acceleration g = 9.66 m/s2 at this altitude. The second component equals 12.90 m/s2 due to atmospheric resistance and is directed oppostie to the velocity. The shuttle is at an altitude of 48.2 km and has reduced its orbital velocity of 28 300 km/h to 15 450 km/h in the direction θ = 1.50o. For this instant, calculate the radius of curvature ρ of the path and the rate α at which the speed is changing?
    hints and tips will be much appreciated.
  3. Dec 22, 2008 #2
    nvn
    jaymar023: The problem statement gives you current velocity and direction, vertical acceleration, and part of the tangential acceleration. Can you use vector mathematics to compute the normal and tangential accelerations from the given accelerations? Also, look for a formula that relates normal acceleration, velocity, and radius of curvature.
  4. Dec 30, 2008 #3
    All I can calculate is a = -8.55 m/s2 and that ρ = 2157647.25 m, but that doesn't seem right too me as I didn't use the angle or change in orbital velocity (only used final) and also didn't use altitude.
  5. Dec 30, 2008 #4
    I used vectors to calculate a and used a = v2/ρ to calculate ρ using v = 4295.1 m/s and a = 8.55 m/s2, multiplying 15450 km/h by 0.278 to convert it to m/s.
  6. Dec 30, 2008 #5
    nvn
    4295.1 m/s is very close. Generally always maintain four significant digits throughout all your intermediate calculations, then round only the final answer to three significant digits. E.g., the conversion factor would be 0.2778.
    The orbital velocity and altitude appear to be extraneous information.
    Why do you say the acceleration is 8.55 m/s^2? Which acceleration? And how did you calculate it? That's not what I got. The angle of the vectors in vector mathematics is important.
  7. Jan 6, 2009 #6
    acceleration i used the vectors a and g and used pythagoras to calculate total acceleration 8.55 m/s^2? Also using trigometry on the angle and velocity i calculated a radius of 4290.54m? but using v^2/r the radius is calculated at 2134.51 km? i am clueless on what to do and don't even no what sort of equations to use to solve the question
  8. Jan 6, 2009 #7
  9. Jan 6, 2009 #8
    nvn
    The radius is not 4290.54 m. Review what you are typing. Also, show how you calculated 8.55 m/s^2. Show all of your calculations.
  10. Jan 6, 2009 #9
    is the answer 1907km?
  11. Jan 6, 2009 #10
    nvn
    That's correct for part of the answer. As you know, the question in post 1 asks for two things. Show your work for the second part.
